Results 1 to 12 of 12
    jsh
    jsh's Avatar
    Feb 2009
    Staffordshire
    114
    RNS-E Mk2 Install - what is needed?
    Hi All
    I'm looking to upgrade to to the latest RNS-E unit with hi-res screen etc. I have searched through the forum but have not found a definitive answer for my car and current spec
    I currently have a Concert double DIN unit installed with factory iPod dock in the glovebox, an AUX 3.5mm socket by the handbrake and Bose speakers.
    Aside of the unit itself and a GPS antenna, what else would I need to order? and is it relatively plug and play (apart from needing to be coded in vag com). I would want so stick with Gen OEM parts where possible
    John
    And back again
    A4 2.0TDi S-Line Cab (2009) Dolphin Grey, Black Fine Nappa, RNS-E DVD Nav, Bluetooth Phone Prep
    Gone....
    S3 Sportback S-tronic (2010) Ibis White
    Going going..... Gone! (and very much missed)
    A4 2.0TDi S-Line Cab (2007) Dolphin Grey, Black Fine Nappa, RNS-E DVD Nav, Bluetooth Phone Prep
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Plug n Play IIRC
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    yup and id not bother about the gps antenna, i have the fin already installed but have only used the none oem gps antenna installed behind the glovebox, regularly picks up 6 sats on average, you really dont need to go to those lengths tbf. For the record ive considered wiring up the shark fin but for the hassle, theres not much point - this coming from someone who prefers OEM too
    Also you'll need to rewire the bose pin and also buy a multimedia adaptor to rewire the aux in, as that will no longer work as it is now....
    other than that you need it coding.....
    Once you have the RNS-E and the multi plug i can remove my unit and tell you where to change the pins to for the aux and bose, its only 4 to change in total
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    656
    Have a read at this!
    RNS-E Installation Into S3 2007
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Adam, that guide doesnt show what he needs to do for the aux pins, the rest of it seems fine though...although let me check where the Bose pin is as mentioned in my post, seem to remember it being different on the facerlift model.....making that guide mostly redundant (no offense)
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    656
    Would be interested to know what ones are for bose!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    same old story bud, Audi changing things for sake of it.....almost certain my recent install required it in a dif place to the guide in the FAQs section
    jsh
    jsh's Avatar
    Feb 2009
    Staffordshire
    114
    Thanks guys for your help so far. ANything else you deem helpful would be very much appreciated
    And back again
    Gone....
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    bit of luck always helps
    jsh
    jsh's Avatar
    Feb 2009
    Staffordshire
    114
    I forgot to add that I have phone prep too
    And back again
    Gone....
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    that will be taken care of when its coded....dont worry bout that, just make sure you tell the chap coding
    27,126
    The antenna system will be different which may then suffer from degraded signal.
    I do these install if ever interested.
