Chris NottAH Fabrications
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Central Electrics Module Relays Help ?
    I've bought a "K" Module not too long ago which didn't included any relays.
    I was wondering As I already have a "A" Module installed in my Newly converted Front end 2010 from a 2003.
    Would it be a straight swap with the Relays ? Or would I need to buy new ones?
    My Module with no Relays :
    This is RS's Module with the right Relays:
    Apr 2011
    197
    Relay positions relay carrier on onboard supply control unit, under dash panel, from model year 2004 are the same upto 2010 and then they change so just swap them over if the relay carrier looks the same
    2004 relays by a8 tech, on Flickr
    1 - Terminal 15 voltage supply relay 2 -J681-
    q Plug position B1 2 - Vacant q Plug position B2 3 - Heated rear window relay -J9- q Plug position B5 4 - Horn relay -J413- q Plug position B6 5 - X-contact relief relay -J59- q Plug position B9 6 - Double washer pump relay 1 -J729- q Plug position B8 7 - Double washer pump relay 2 -J730- q Plug position B7 8 - Vacant q Plug position B3 9 - Terminal 30 voltage supply relay 2 -J689- q Plug position B4
    ~RS~'s Avatar
    Feb 2009
    1,463
    Ahh so that's why my washer jets are not working, lmao!
    Cheers mate. Sure this will help me and digzz sort out his fuse locations
