Monster MotorsportChris Nott
Results 1 to 12 of 12
    Oct 2010
    92
    Leaving car garaged for a few months - advice needed
    I'm going travelling for a few months and am going to declare my car off-road and keep it stored in the garage, but is there anything I should do it before leaving it for this long? Is it even wise to leave it this long or should I get a friend to go start it once every couple of weeks?
    It has been suggested that I disconnect the battery, which seems to make sense, but would this cause any problems?
    Mar 2011
    Wolverhampton
    125
    Either disconnect the battery or just get a cheap halfords trickle charger and leave it plugged in. It will be fine either way, but i would advise against starting it every now an then unless you are taking it for a 20min run at least as it will do more bad then good, mate.
    Oct 2010
    92
    Quote Originally Posted by asasprey View Post
    So disconnecting it for 3 months won't cause any problems?
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    as said with the battery, also make sure all the fluids are nice and full
    also depending how long a few months is, may be worth putting it on axel stands to save flat spotting the rubber
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Mar 2011
    Wolverhampton
    125
    Quote Originally Posted by owenjt View Post
    Not unless resetting your date is a problem lol. You will have a couple dashboard lights on when you reconnect her, but these should go out more or less immediately when you start to drive. Im not sure if leaving it disconnected for so long would cause it to lose the radio code, but thats no big deal either really.
    Mar 2011
    Wolverhampton
    125
    a9503128
    Depends upon the age of the battery, my car was parked up for 9months while the previous owner was working the US. He came back to sell it to me and we checked all the levels (oil, water) and it cranked over first time.
    Just a dry location with good ventilation, clean and DRY it, anti-freeze and oil check (poss change) make sure the air in the tyres is the right pressure if you can remove them and rest the car on stands (old trick for putting a motorbike away for the winter), DONT put the handbrake on (if possible IE stored in a level and locked garage) and finally lube all the locks, cables, hinges etc and spray WD40 all around the engine bay (gets rid of water) before you put it away. Don’t get tempted to cover it with a sheet that’s how moisture starts.
    When you get back check the levels, spray more WD40 and leave to rest, check tyres, and roll the car back and forth to make sure nothing has seized, check the levels AGAIN, if petrol you can get Stale fuel (did on the bike) so a shot of redex will help. All this is BEFORE you start It then take it easy with the car and test your brakes and controls at a nice low speed and then give her a clean and a new car magic tree..
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    It depends what kind of garage you're leaving it in; what colour the door is; the postcode of the garage; the type of lock on the door; whether there's anyone within sight of it at all times; etc... I'd love to help, but it simply isn't a question that can be answered without giving us a lot more info to go on.
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Oct 2010
    92
    Quote Originally Posted by jungleman View Post
    Probably about 3 months.
    Quote Originally Posted by a9503128 View Post
    Think battery is original, car is 2005. Good point checking fluid levels, why not put the handbrake on?
    Quote Originally Posted by mitch78 View Post
    An extremely secure and remote garage that's impossible to find unless you can decipher the hidden map and even then it's monitored 24hrs by security cameras and guarded by huge dogs with big teeth and entry requires a fingerprint and retina scan ;-)
    Apr 2011
    80
    We leave cars for up to 12 months around 3 or 4 a year. And a lot of our cars sit for 3 months and start first time and we leave the handbrakes on with no problems what so ever. We leave the battery's on as disconnecting them tends to throw up warning lights.
    Black 3dr 1.6FSI A3 54plate
    Done.....
    K&N Air filter , My11 Rear lights , S3 Pedals
    Still to do
    Front grill conversion (just need a bonnet) , S3 wheels , Sline steering wheel
    Wanted
    S3 wheels , S Line Steering wheel
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    i think leaving the handbrake on is only an issue if its being left outside but in a garage then should be ok just make sure the car is bone dry even all the brakes otherwise if you leave the handbrake on with it wet or damp it will stick on and is a bugga to free after a day let alone a few months
    off the road boohoo anyone got a gearbox for me lol!!
    a9503128
    Re why the handbrake off, brakes dont stick as long as dry (wet they rust) its just the cable will stretch if left on tension for long periods. It just prelongs life of cable and saves you a few quid.
