Volks AutosJMB Retrofits
    Mar 2011
    paisley
    16
    A BIG THANKS TO CRUNCHIE
    car finally sorted sourced a coupling from ayr audi fitted myself in an hour now vibration and noise free thanks for your help...........
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    What was the initial problem? Symptom mate?
    Moved to the Darkside click below:
    Mar 2011
    paisley
    16
    Quote Originally Posted by Smoothie View Post
    I had a bad vibration and loud noise when driving at speeds between 65 to 85 mph /2.2 revs to 2.8 turns out the rear prop damper on the quattro tdi have a design fault basically you have an outer steel ring with a rubber coupling inside bonded to the outer ,there is three moving segments to the rubber part which are about 1mm from the inside edge of the steel ring. The ring is not treated [bare metal] so it rust up inside stopping the rubber damper from moving and not acting as a damper......... iam going to treat with some waxoyl and check every 6 months or so....
