Chris NottBadger5
Thread: buying an s3 8p
    Apr 2011
    buying an s3 8p
    Hi all
    New to this web site
    Iam in the process of buying a 2007 s3 which has 58k on the clock has full audi history looks nice and getting a good deal on it i think! Apart from cam belt is there anything else i need to worry about with milage and costly service intervals? Any info would be greatly accepted.
    Thanks Stuart
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    656
    Make sure the haldex has been serviced iirc.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    the only other thing is get them to make sure they have checked to see if the coilpacks on it are part of the recent recall
    apart from that you should be good
    oh and check the condition of the clutch, as with that amount of millage it could be on its last legs
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Apr 2011
    Thanks guys also being a private sale would use/ bother with somthing like aa vehicle inspection quite expensive but thinking about peace of mind or does anyone know anyone cheaper live in essex and car is close buy!
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    ah its a private sale, depends how much they are, but would be worth it as they should be able to uncover any little hidden secrets, that way youll have a better idea of what your getting, gives you, if needed room to haggle over the price or walk away and save yourself a fortune down the line as these things arnt cheap to fix if they have problems!
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    As said, check coil packs - if the car has been recalled, the revision number should have a "D" at the end.
    Clutch - check for slippage.
    Have you vagcom or access to it? I would try get a hold of it and do a fault diagnosis on the car prior to any decision making.
    Knocking in steering while sitting at idle
    Juddering at idle - if it does, then flywheel is on way out.
    Cam belt would need done ASAP as the car is reaching 60k and 4 years old
    Haldex service
    Check that glove box lowers slowly and doesn't just drop down - would mean that mechanism is broken
    If it has an armrest, check the clasp as these are prone to breaking
