Ok a far as I'm aware the EGR can be turned down to a minimum (not turned OFF completely)using VCDS, I think drilling a smallish hole (2mm)in the blanking plate for EGR cooler can temporarily reduce CEL light coming on but a tuner/mapper can disable the Check Engine Light completely
