JMB RetrofitsEM Tuning
    pazaz's Avatar
    May 2004
    S.Wales
    316
    Elec Windows Playing Up??
    My 07 sportsback front elec windows have started playing up.
    Sometimes they only open a tiny amount then stop. If I then close fully and hold the switch up they seem to be ok again and work properly?
    Today I was trying to open both fronts at the same time and they where both opening bit by bit in stages?
    Any Ideas?
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Hold the button to drop the windows fully, then hold until they go all the way to the top again
    Thats how i fixed mine this week!
    Apr 2011
    80
    Just need reseting like moag said.
    Black 3dr 1.6FSI A3 54plate
    Done.....
    K&N Air filter , My11 Rear lights , S3 Pedals
    Still to do
    Front grill conversion (just need a bonnet) , S3 wheels , Sline steering wheel
    Wanted
    S3 wheels , S Line Steering wheel
    27,099
    TBH you can just hold the up switch even when closed until you hear a faint click, this should also reset them, tested ther day after a brainwave & it worked.
    This was tested on updated door modules, so have to see if it works on older 07 modules.
