EM TuningAH Fabrications
Results 1 to 22 of 22
    Mar 2011
    78
    audi s3 2009 service?
    hi guys whats the best plugs to use and the best oil to use and does anyone know how to reset the service light?
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    DIY Service on a 2009 S3?
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    yarp dealer that mofo
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Mar 2011
    78
    well i got the 3 year plan but i want somthing better than standed oil and plugs whats wrong with that?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    Quote Originally Posted by j7yob123 View Post
    The current advice for tuned cars is to use the standard plugs,but change every 5000 miles or so....this seems to have worked pretty well on mine so far.
    Oil...go again with a good quality long life synthetic(Castrol Edge or Mobil 1),but change more regularly than the standard schedule,so 5000 miles is a good guide,when you have the plugs changed.
    The 3 year plan can be pretty good value if you get the right price deal,and ensures you're covered from the warranty angle although the work you've had done will invalidate that anyway.
    Why do you need to reset the service light?...haven't you just had the car remapped etc?
    And on that...how's the car going?
    Mutsumi's Avatar
    May 2009
    58
    tbh, dealer prices on consumables like spark plugs and oil is a joke too. Audi Swindon want £95 for 5 litres of oil and another £60 to put it in. I'm fine with the labour charge, but I'm supplying my own oil!
    My 07 S3 will be happy with any oil that meets VW 504 00 according to the manual (Both variable and fixed). Look on the back of the bottle, most big manufacturers like Shell, Mobil etc will have it there. However, the manual says nothing about viscosity...
    2007 S3 - Swivelly headlights, magic foldy mirrors, two tone warm cow seats, beepy reverse, lazy motorway button, well good talky radio with telly & map, loads of lights inside, squished steering wheel, Milltek cat-back loud bits.
    Mar 2011
    78
    s3 alex hi its saying need service in 500 miles so wanted to change pluss oil and oil filter next week and i rember on my old audi you use to do sonthing with the key and the button on the dash to to reset the display that tells you u need a service
    Mar 2011
    78
    got warrenty work being done on fri 6th hoplfully they dnt give me any crap its my air con its stop ive been told comman fault?
    Mar 2011
    78
    and cars running ok sometime a feel like its holding back abit like not enough fuel but i will get amd to do a map more aggrisive when i do my clutch but so far no slipping
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    On a car that new,and under warranty,I'd take it back to the dealer and just get it serviced as directed.
    They'll do the oil and whatever other bits are required,and the plugs you can either get done there,or at AMD the next time you're near as it's not a long job.
    As far as I know,there is nothing on the dash/key to reset the indicator,and you need this doing for you....most dealers are not bothered by cars that have been mapped etc,although if anything breaks,you know you won't get help on any modified areas.
    Mine was in recently having a routine service,and they clearly knew it had been slightly modified....the only question was how much power,which was quite amusing.
    If you're getting a misfire or something similar,there are a lot of causes,but plugs and coilpacks are the most common...on yours,fuelling should not be an issue as you have the HPFP fitted,and strictly speaking,you shouldn't need an RS4 fuel pressure regulator at Stg2+ either.
    Mar 2011
    78
    what has your car got except the turbo ?
    Mar 2011
    78
    lol just see it sorry what bhp and touqe u got?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    You need to get registered and posting over at the other forum....!...then you can see the threads and the builds.
    Apart from the turbo.....quite a bit incl the obvious like HPFP,ITG intake,modified induction and exhaust systems,RS4 fuel pressure regulator,and so on...
    Power.....about 440bhp and 420lbs of torque....don't forget that even with a good aftermarket intercooler,you will lose a bit on hot days,and that the RR thing is always a bit of a lottery.
    Much more than that,and you would be at the point where you need to get the internals done,to bring down the compression ratio and toughen up the bottom end,or you'll end up with either bent rods or holed pistons......I would also rather have a useable 450bhp than a screamer that only delivers at high rpm.
    What you want is to see the gains you get on the SAME rolling road before and after a set of mods has been done,and having a couple of cars with this sort of power/weight ratio before,I think the figures are about right.
    Mar 2011
    78
    what the other forum site and thats what im aiming for the 420 to 450 mark what clutch are you using?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    my amd vist today
    I put quite a bit of information on there for you....
    I've already said that I've got a Sachs,and that most of us use that,but there is also the Helix and the Southbend,but the latter takes a SMF and that will give you lots of vibration and harshness.
    The other site is VAGOC....come on over,make a few posts,and find a few others with cars like this.
    Mar 2011
    78
    im already a member other on that just never got the hang of using that site thx for info
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    It works just like this one,but you do have to make a few posts before you can get into the good bits like the rides.
    Mar 2011
    78
    one more thing i find my induction kit pipe and cone gets very very hot is the somthing out there that is alot better ? i have the evoms
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    OK...the Evoms is matt black,which is the perfect colour for heat absorption....coating it with gold tape may help.
    Dust Buster, Air Precleaners, Spark Arrestors, Engine protection and ancillary products, for the earthmoving, agricultural, truck, bus and the automotive markets.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    well as its in a hot engine bay its going to happen, next week im going to be wrapping mine in this stuff:
    REFLECT-A-GOLD - TD010394 1.5"X15ft ROLL
    not sure if you will need one or 2 rolls, when you had your TBE fitted should have wrapped the exhaust in some titanium heat wrap as that keeps a lot of heat out the engine bay as well
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    haha you beat me to it alex lol
    Mar 2011
    78
    thx guy will order that tomoro
