Volks AutosChris Nott
Results 1 to 9 of 9
Thread: r32 calipers
    Oct 2009
    63
    r32 calipers
    hi lads ive just found a set of r32 rear calipers and carriers will these fit straight onto my a3 2.0 tdi 58 plate and what size discs can i use with these
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    why would you want to upgrade the rears?
    have you upgraded the fronts?
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,807
    same question as below have you done the fronts?
    Dark Vader Half sibling - MyThread
    Oct 2009
    63
    yeah fronts are done
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    to be honest its still not needed, the VAG group generally oversize their rear brakes out of the factory.
    a massive majority of the braking force is done by the fronts, although the rears do help slightly with braking, they are mainly there for helping with stability on high speed braking, to give you an idea im running 4 pot racing brakes on mine and havent touched the rears as its not needed, and i also know a few guys with TTRS's running 8pot RS6 brakes and again they havent touched the rears and these guys track the cars very very hard!
    another thing you would have to consider it if your upping front and back you may have to change the brake master cylinder to compensate or you could end up with a lot of pedal travel! so personally i wouldnt bother
    Oct 2009
    63
    i know but there cheapn you see so and they will look better than the rubbish ones on at moment. so will they fit
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    as its the back im not sure, but id be surprised if it didnt as it should all be the same, unless yours is only a fwd as there may be differences with the 4Wds, but i doubt it, and like i said in doing the front & back you may get much further pedal travel
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    652
    Should be fine.
    Pedal travel should not be affected and it will stabilize the car more under breaking.
    Piston size is the same on both calipers.
    Oct 2009
    63
    just need to know what disc size i can run
