JMB RetrofitsBadger5
Results 1 to 11 of 11
Thread: Brake Upgrade!
    Gregzy88's Avatar
    A3 Newbie
    Mar 2011
    Aberdeen
    70
    Brake Upgrade!
    So, after getting remapped I have decided I want to upgrade the brakes as I can't slow down quick enough. Just wanted to know what my options are.
    Audi A3 2.0 TDI S-Line
    Mods: Stage 1 Engine Remap by Angel Tuning, K&N Panel Filter, Rear Window Tints.
    To Do: Black Optics, New HUD, Straight through exhaust.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    your most cost effective option is getting the brakes from an S3/R32 as these are a straight swap and will give you a much better braking performance
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Gregzy88's Avatar
    A3 Newbie
    Mar 2011
    Aberdeen
    70
    Quote Originally Posted by jungleman View Post
    I thought that would be the easiest way after searching through similar threads. Any idea of how much it is to do the S3 brake conversion? Cheers.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    it shouldnt be too expensive really, somewhere between £3-500 for the discs, pads lines & callipers. if your paying towards the top end of that, you want to make sure there is lots of life left in the pads & discs or youll end up spending another couple of hundred in replacing them
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Go on ebay you can normally get a full set for less then £600 and there a member on here selling complete front set up for £350 on the ebay thread.
    Dark Vader Half sibling - MyThread
    27,126
    Yeap the 345mm brakes are a worthy upgrade for that price, have done to both our cars & they work very well.
    Gregzy88's Avatar
    A3 Newbie
    Mar 2011
    Aberdeen
    70
    Quote Originally Posted by Ash_B View Post
    Cheers mate, do is it only the front brakes that would be worht changing or the whole set?
    In fact if anyone could tell what i would need for the whole S3 brake conversion that would be great.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I have a full S3 front set for sale now if you are interested?
    Came off a facelift 8P S3 and have plenty life left in them, PM me if you are interested.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    These are the parts you need if you want to buy them separately.
    LH CALIPER 1K0615123K
    RH CALIPER 1K0615124K
    CARRIER 1K0615125G - 2 pc
    LH SHIELD 1K0615311C - 1 pc
    RH SHIELD 1K0615312C - 1 pc
    BOLT N10647602 - 4 pcs
    SCREW N90948802 - 4 buc
    SCREW N91073301- 6 pcs.
    BRACKET 1K0611841A - 1 pc
    BRACKET 1K0611842A - 1 pc
    SCREW N90718601 - 2 pcs.
    CLIP 191611715 - 2 pcs.
    RETAINING SPRING 4F0615269 - 2 pcs.
    PAD SET 1K0698151B (I bought DS2500)
    BRAKE DISC (345x30mm) 1K0615301M (I'm waiting for a set of Tarox F2000)
    PIPE 1K0611763A - 1 pc.
    PIPE 1K0611764A - 1 pc.
    FLEXI HOSE 1K0611701N - 2 pcs. (I have a complete 4 pcs set of HEL SS lines; I've heard that if you go for the HEL lines, you won't need the two pipes above; I'll see when I'll fit them to the car)
    This is what I've bought for my conversion. The codes are for Cupra brakes which are almost identical to S3 and R32 brakes. The difference is the color (red for Cupra, blue for R32 and black I think for S3; also S3 has the logo on them). In Romania the components ordered on Cupra codes are cheaper than the ones with S3 or R32 codes.
    Also, some of the screws and bolts mentioned are not mandatory, you can reuse some of the existing ones. For safety I've ordered new ones.
    If you decide to buy the whole kit from someone you may end up paying less. Since I didn't had enough money at once, I bought it by pieces.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Mar 2011
    Wolverhampton
    125
    Porsche calipers!!
    cata_adc's Avatar
    May 2010
    Ro/ Brasov
    92
    go for the s3/cupra/r32 brakes .
    I'm very happy with them. Huge difference from the old 288 discs
