Chris NottAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
Like Tree2Likes
Thread: ESP Fault please see owners manual
  1. #41
    mikex709's Avatar
    Jun 2010
    114
    Thumbs up
    Just a quick update: I got my ABS Pump pressure sensor issue by VAS Motion - The VW, Audi, Seat and Skoda Specialists Garage, Guildford who are a lot closer to me than VOLKSMASTER OLDHAM - AUDI VW SPECIALIST I cannot fault VAS Motion work at all, made me feel welcomed, offering cups of tea and wifi access whilst waiting. The cost was £380 inclusive of ABS pump repair kit and fitting, can't recommended them enough...!! These lads are ex-audi tech master and certainly know their stuff, their workshop is spotless and clinically clean, ask for Gavin Page or Gareth Berry. Job well done
    UPDATE: BTW it comes with 2 years warranty too...
  3. #42
    Aug 2005
    West London
    850
    Thats good to hear about another garage offering the service. Thanks for the feedback.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
  4. #43
    Dec 2010
    68
    I'm almost certain this is the message I've just started seeing on start up. Like the OP, mine flashes up for less then half a second - hardly enough time to read it, along with the warning tone. The car starts and runs normally and no warning lamps come on.
    In my other thread (Weird DIS message) that I started this AM Nige suggested it may be related to the fact the front brake pads have just been changed. The car was at Bradford Audi last week for its AVS and had the pads changed while there. I'd never seen this message before and only started getting it since it had the work done.
    I called them this afternoon and their technician told me it was normal and just showed the computer was doing a self check. This seemed odd, if that's true why has it not done it before now?
    What do you think? Am I being fobbed off?
  5. #44
    Aug 2005
    West London
    850
    If you have the G201 pressure sensor failure you will have the ABS light on all the time as the system will notify you its not working. If you don't have the ABS light on all the time then the system is active and working (you can double check by holding the button down and see if it notifies you when its deactivated).
  6. #45
    Jul 2011
    13
    I am led to believe that you have to have both the warning symbol in the instrument cluster and the system off switch illuminated to signify an ABS pump sensor failure, if it's just the esp fault message could it be just a wheel sensor thats gone.....
    Many thanks
    Michael
  7. #46
    DaveyB's Avatar
    No misfires.
    Jul 2010
    UK
    268
    I havent posted for ages but once again ASN proves useful.
    I have been getting the split second flash up error of ESP fault on start up intermittently for a few weeks now but my ESP switch works perfectly and i still have manually control switching the system on and off. No errors ever saty up on the DIS.
    To make things even stranger, and as mentioned earlier in this thread, my mirrors have also started folding themselves out on start up( when switch set to close in) , something they have only done over the last week or two.
    My xenon lights flicker badly after levelling on startup (when set to 'AUTO' lights) but a quick flick of the switch to 'off' and then manual dip beam cures this instantly but if left on 'Auto' it takes a kinute or two to sort themselves out of the flicker. When actiavting main beam it sounds very 'clonky' in the engine bay.
    I can help think this could be a battery issue, even though the car starts perfectly. I suppose the first port of call would be a battery test.
    Any thoughts welcomed. Many thanks
    07' S3 8P2 Phantom Black Pearl
    91' Mercedes 300SL R129 Pearl Grey
  8. #47
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,204
    Quote Originally Posted by DaveyB View Post
    sorry for the huge bump, did you get this sorted?
    my cars similar flashes up with it for a brief second. also windows wont open for the first 5 seconds or so.
  9. #48
    Mar 2012
    278
    I was getting this error message and warning bell on first start up too - literally lasting a split second - and usually happening when the car had been sitting over night. After that first start up of the day, it wouldn't happen again until the car had been left for a prolonged period of time. My theory was (and as backed up on the first page of this thread) that it was a voltage issue caused by a failing battery - it was not holding a charge and slowly draining away when left a while. After a couple of months of this 'problem' first starting, my car battery died completely.... And would you know it? Since replacing the battery, I've not once had the message! I wouldn't be surprised if this cold weather is killing off your battery too - may even be the cause of your window issue (electrics are a funny thing)
    Also, don't start up the car straight away. Turn the ignition one turn (so that the dash lights up), wait for the ESP light to disappear from the dials, then turn again to start the car. I think that it's engaging/error checking whilst the symbol is lit up on the dials, and if you start up before the light goes out, it can confuse the car and throw up the brief error message
  10. #49
    sliced's Avatar
    Jun 2012
    1,204
    Quote Originally Posted by SCFC_Messiah View Post
    cheers will get to battery checked out, as i have subs and amps in the back :$
  11. #50
    sliced's Avatar
    Jun 2012
    1,204
    battery at 74%, time to replace?
