Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Apr 2011
    80
    Best way to connect a Iphone4 (for music not phone) to a concert Head Unit ?
    thanks
    Black 3dr 1.6FSI A3 54plate
    Done.....
    K&N Air filter , My11 Rear lights , S3 Pedals
    Still to do
    Front grill conversion (just need a bonnet) , S3 wheels , Sline steering wheel
    Wanted
    S3 wheels , S Line Steering wheel
    27,032
    Why not upgrade to a rns-e mate & use sd cards?
    Could add an aux in 3.5 jack socket & use iphone to control tracks.
    There are other devices, maybe a Dension unit.
    netr's Avatar
    Jun 2010
    Ljubljana, Slovenia
    51
    I am also interested in this answer... Research till now has led me to believe, parrot mki9200 would be the best option (and also you get bluetooth, aux, usb)... And you get maximal control with the included display.
    As I am aware the Dension units don't display anything on your headunit (Concert 2). And you are limited to only 6 playlists... And much more drawbacks...
    Nov 2010
    Leeds, UK / Antibes, France
    223
    AUDI::XCarLink
    This is What I'm using until I can afford an RNSE 2.
    Everything hidden, bluetooth connection to my iphone 4 and play music that way.
    Mar 2008
    Bradford, WY
    788
    I use the audi ipod connector with concert hu. Will play music fine. If you want it to charge iphone4 aswel you need a little belkin charge pin convertor adaptor. Have used it with all iphones
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    I really wanted ipod connection when i got the A3 but havn't looked back since installing the RNS-e! SD function is great especially with steering wheel controls
    Moved to the Darkside click below:
    Mar 2008
    Bradford, WY
    788
    I think id rather wait for a touch screen rns-e, if they ever make one
    27,032
    Isnt gonna happen mate, unless you use an overlay that is programmed as such with can signals for areas of the screen & modes.
    RNS-E will be its last incarnation, as I suspect all audi's going forth will be fully integrated, not a head unit as such, look at the A1 & thats the lowest model, so the new A3 will be same or better.
