Monster MotorsportEM Tuning
Results 1 to 18 of 18
    Mar 2011
    9
    Straighten the exhaust end tips of a 2.0TDI
    Hi guys,
    I've searched for this in the forum, but couldn't find answers (cause I probably didn't use the right words).
    As most of you know, the "old" 2.0TDI endpipes aren't straight:
    I want to fit on chrome end tips, so I must cut off the curved end...
    Has anyone of you ever done this, or is there a "tutorial" or "how-to" available to sort this out?
    Thanks!
    munchkincoupe's Avatar
    Aug 2010
    971
    I've just fitted the Audi Extension tailpipes to my 2.0 tdi - will post pic up tomorrow but looks 100% better - got them from supplier on ebay for 40 - Audi wanted 120 for them!!!
    Aug 2010
    971
    This is the link to the ones I fitted but I have the Votex kit NEW GENUINE AUDI A3 2.0TFSI TDI 170 BHP EXHAUST TRIM | eBay UK
    If you email them they did have the other ones advertised too
    Dec 2010
    370
    would those ones not fit a standard valance then?
    Mar 2011
    9
    @munchkincoupe, thanks for the link, but those wont fit my car. Also, are your endpipes already straight? Mine slightly bend downwards...
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Will that fit an s3 diffuser?
    Audi S3 8P2 Silver
    BI-Xenons - FBMFSW - Rain/Light Pack - Auto dim package - iPod Integration - 2011 Nav - Electric Folding Mirrors - Rear Park Sensors - Full Heated Leather - BOSE - Privacy Windows - 2011 Console Conversion - My11 Rear Lights - RevD Diverter - Forge DMV14T BOV - ITG Maxogen CAI - BBS CH 18s
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    I'm pretty sure the downward part would need cut off. Any exhaust place would do this in about 5 minutes with a gas powered hack saw. Some might not even charge you. If you can work out the diameter of the pipe then I dare say a trim could be fitted over what's left if there is enough straight pipe. If not then it would be a welding job.
    Maxumo's Avatar
    Mar 2011
    Cardiff
    88
    Quote Originally Posted by tiesva View Post
    I have the same problem, if you buy the exhaust tips take them to garage and they will angle grind the downward pointing end bits and weld the tips on, but make sure they are on straight as some people have had them done and they didn't look very straight.
    A3 S Line 170 Phantom BlackPearl
    Aug 2010
    971
    Mine were downward facing tips. The Audi part requires that you cut them off and weld these in place. Quality piece of kit though. Not the lightweights tips you may get off ebay
    Aug 2010
    971
    If you email them they do stock the tips for non-votex kit and also for later models with the straight pipes
    Scott_Hol's Avatar
    Aski Champion
    Jun 2010
    Sunderland
    583
    Would these fit on mine if i got the droopy pipes cut straight as i think i have a votex rear but mine is a 140
    Aug 2010
    971
    No you need the same as me 8p0 071 911
    I have the 140 and what looks like exactly the same colour/kit as your car Scott!
    Scott_Hol's Avatar
    Aski Champion
    Jun 2010
    Sunderland
    583
    Quote Originally Posted by munchkincoupe View Post
    Could you send me the link m8 cheers
    Aug 2010
    971
    If you email that seller on ebay - partsdepot_uk - and ask them for the other part number mate
    Scott_Hol's Avatar
    Aski Champion
    Jun 2010
    Sunderland
    583
    Cheers m8
    scottie123's Avatar
    Oct 2008
    1,888
    Just to clarify for you all
    To remove the droopy part of the exhaust is easy.
    The actual 'droopy' part is a sleeve which goes over a straight pipe
    It is only held on with iirc 3 small tack welds at the end closest to the backbox
    These can easily be ground of with an angle grinder/dremel.
    Once these welds have been removed, the droopy part will just slide off leaving you a nice straight pipe to fit your new
    Exhaust trims too.
    Hth
    05 SB SE BKD
    Build Thread
    Scott_Hol's Avatar
    Aski Champion
    Jun 2010
    Sunderland
    583
    Quote Originally Posted by scottie123 View Post
    Exhaust trims too.
    Hth
    Good Info fella cheers
    Aug 2010
    971
    Here are the Audi trims that I fitted to my 8P1 140bhp
