    a9503128
    Can Double Din Card Holder be swapped for a drinks holder
    Hello
    As the title says, can the Double Din Card Holder be swapped for a drinks holder? The card slot is of no use but a coffee cup holder would be.
    Alex
    May 2010
    2,502
    age of car?
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    a9503128
    its a 2006 car.
    robp_kent's Avatar
    Jan 2011
    Kent
    20
    Retrofitted cupholder this might help then.
    I followed it for my 57 plate
    A3 TDi S Line DSG Lava Grey, Leather, Bose, 18" Split Rims
    Mods: Ambient Lights, Puddle & Footwell lights, Tints, Exhaust Trim, Mudflaps, Wind Deflectors Cup Holder Mod
    Nov 2006
    51
    Yes it can, but you will need to pull out the surrounding plastic cover lets call it, and enlarge the opening a little on the sides so that the cup holder can fit in.
    c_w
    1,061
    I think most people have swapped the front cardholder "cover" on to the drinks holder so it fits the slot in the switch surround plate. However it doesn't actually just "clip" on. I think opening up the switch surround to accommodate the drinks holder cover is a good idea but may not give the desired smooth edged finish in the dash - I think either way there's a bit of DIY involved in this.
    I found there was a lot of dremelling to fit the cardholder cover on to the drinks holder and even then had to set it with super glue. It now works fairly well. I do not know why AUDI chose to drop the drinks holder with the doubledin headunits.
