Badger5EM Tuning
Results 1 to 12 of 12
    Jun 2009
    1,069
    A3 tdi 140, starting problems.
    My mates audi a3 140 tdi doesn't start sometimes, he notices that if not used for a day that in the morning it doesn't start. It's been to the garage twice and Ł500 spent and it still does it. He gets it to start using easy start but said he had to have the accelerator fully down. So it is a fuelling issue, I was thinking maybe a tiny fuel leak then pressure dropping, but I've told him about priming it a few times before starting, yet it still didnt start without easy start. Anything obvious?
    Its gone replaced with a mk2 golf gti 16v :D
    Apr 2011
    6
    Mines exactly the same. For some reason it's been fine for the last 4 months up til this week. Playing up alot this week, if I get my foot down on the accelerator quickly when it's struggling It doesn't need the easy start. My mate reckons maybe the fuel pump? No fault codes or lights.
    Jun 2009
    1,069
    Ermm, thats what I said, it sounds fuel pressure related, but if it was the fuel pump it'd do it often, instead it does it when he doesn't use for a day or two. Yer putting foot down on the accelerator maybe adding extra fuel needed to start it. These modern cars are a pain in the arse! lol
    Apr 2011
    6
    Mine can be fine when i drive to work, then 10 hours later it plays up so not even days for me. First time it did it about a year ago the RAC recovered me thats how i found out about the easy start trick. He said maybe the EGR valve or the one next to it whatever that its cant remember, but ive had both replaced. I thought it had cured it but 4 months later its back. hopefully someone can help us?
    May 2010
    Birmingham
    100
    What is this easy start trick?
    Apr 2011
    6
    Well hardly a trick but the car won't start unless I open the air filter box and give it a blast of easy start. It's the only way. I've only ever needed to do it twice though normally foot on accelerator is enough. First time it happened that how the rac chap started it. Same model as emerys friends. 2.0tdi
    Jun 2009
    1,069
    Yer it's like a spray, never used it, but if your car won't start, use it and if it starts it's likely a fuelling issue, if it doesn't then it's spark. I don't know but could it be a dodgy maf? Sometimes doesn't recognize the air coming in and under fuels. Erm it's weird though!
    Apr 2011
    6
    Emery what work has your mate had done by the garage? If it was the maf wouldn't it throw up an error code?
    Feb 2011
    Preston
    64
    Quote Originally Posted by emery1990 View Post
    Hey guys,
    One of my mates had a similar problem on his 1.9 Passat. It turned out to be a wiring loom in the engine, so it could possibly be this as the fault sounds similar.
    Hope you guys sort it out soon!
    Apr 2011
    6
    Thanks aky. Looks like I'm gonna send it in to audi if it carries on as bad as its got so I'll mention that to them.
    Jun 2009
    1,069
    Cheers mate I'll tell him, I'm not sure but he said they was specialist and that an auto electrician came out, so prices just added up, dont think they done any repairs or changed any parts.
    Feb 2011
    Preston
    64
    Good luck in sorting it guys!
    I think my mate ended up paying around the Ł400 mark, if I remember right. His car wouldnt start until the recovery guy came and sprayed brake cleaner in the air box and it started.
    He took it to Carford Garage in Preston (Bray Street) and one of the dudes there is ex VW group and pretty good. Not quite sure if this is close in relation to where you are from.
    But they are good and dont charge outragous prices. Think he exact falf was one of the 60 wires in the loom was corroded and not a simple task to work out which one so best to change the whole loom.
    Hope this helps.
