AH FabricationsBadger5
Results 1 to 11 of 11
Thread: new pics
    Feb 2004
    Clearfield, PA
    892
    new pics
    well mr TTLAw put some up today so thought i would post some pics from the weekend..
    ive put them on www.vagowners.com
    its as a feature car at the moment.. only some pics.. in the process in coding the pages to do write ups etc.. so bare with me on that one...
    let me know what u think..
    obviously the sites under major work at the moment but hopefully will get everything sorted.. lots more is to change including text and pictures etc.. but wait and see anyways..
    Feb 2004
    Clearfield, PA
    892
    Re: new pics
    lol he he.. black..
    Oct 2004
    62
    Re: new pics
    Nice motor could do with dropping a tad though.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Re: new pics
    Looks spot on Richy, not to OTT, cool backdrop.
    Feb 2004
    Clearfield, PA
    892
    Re: new pics
    LEE.. coilovers are on order and have been for over 4 months now. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Jul 2004
    S.E. Essex
    152
    Re: new pics
    richy - sorry to be a clutz - but what exactly are coilovers? - how do they effect handling? howmuch and howeasy tofit? oh and howmuch do they lower the car? - thanks for the info... [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Feb 2004
    Clearfield, PA
    892
    Re: new pics
    mine will be adjustable height and dampers allowing me to adjust how firm the ride is and also the hight of the car.
    i think they will allow me to adjust the hight from 25mm to 90mm
    i know on the Golf MkIV you could lower the car by 120mm but you had to do adjustments with a few things.
    im not fitting it myself im sorry to say as i had a good quote to have them fitted when they come and it worked out better for me..
    but do not fear... pictures will be taken when i get it sorted.
    Karcsi - yeah a smokers tooth bruth from the supermarket and some tar remover works good.. although still have a long way to go untill they are perfect..
    synthdood's Avatar
    Oct 2004
    Amsterdam, Netherlands
    286
    Re: new pics
    If you have ajustable height, how easy is it to change the height/firmness? Do you have to take it in to the dealer/specialist?
    Mar 2003
    UK
    426
    Re: new pics
    Any need to have tracking and such like checked between setting changes?
    To lower a car, so both the dampers and springs have to be changed, or shorter springs enough? Or does it depend on how much shorter I want the springs (lower the car) to be?
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: new pics
    Fitting coilovers or any springs isn;t thatmuch of a job if you can wield a set of spanners.
    I've done the suspension on quite a few cars now!
    Adjusting the height on coilovers is pretty straight forward but can be a complete pain getting all four corners at the same height - sounds easy but it's not trust me on this.
    Adjusting the damping, depending on the kit, is very quick and simple to do. Most of them can be done on the car - well on the front anyway. A lot of them require the shocks to be removed from the rear though.
    You should always get the tracking checked after adjusting the height of the car. Ideally you need to let springs settle before getting the tracking done - either a week or about 500 miles is normally enough during which time you can play around with the height tll your happy.
    J.
    Feb 2004
    Clearfield, PA
    892
    Re: new pics
    as married blonde said..
