Volks AutosAH Fabrications
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,775
    2004 A3 TDI 140 Fault Codes
    Anyone any experience in the below?
    http://wiki.ross-tech.com/wiki/index.php/18359/P1951/006481
    http://wiki.ross-tech.com/wiki/index.php/01274
    http://wiki.ross-tech.com/wiki/index.php/01739
    http://wiki.ross-tech.com/wiki/index.php/00929
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Sunday,10,April,2011,17:54:34:32181
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P54A083683 Mileage: 168380km/104626miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5334
    Revision: 12345678 Serial number: AUX7Z0C8FNA05O
    Coding: 0000072
    Shop #: WSC 79431 024 394950
    VCID: 2759957DEF6B
    2 Faults Found:
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1407 /min
    Torque: 6.0 Nm
    Speed: 25.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 00000100
    Temperature: 61.2C
    Duty Cycle: 25.1 %
    18358 - Radiator Fan (V7): Movement Restricted / Jammed
    P1950 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1806 /min
    Torque: 92.0 Nm
    Speed: 46.0 km/h
    Load: 26.3 %
    Voltage: 14.52 V
    Bin. Bits: 00000000
    Temperature: 35.1C
    Duty Cycle: 9.6 %
    Readiness: 0 0 0 0 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 HW: 8P0 820 043
    Component: KlimavollautomatH11 0130
    Shop #: WSC 00000 000 00000
    VCID: E9DD5345B9FF
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 56
    Reset counter: 31
    Mileage: 160157 km
    Time Indication: 0
    Date: 2010.09.13
    Time: 13:42:55
    Freeze Frame:
    Voltage: 14.30 V
    Temperature: 19.0C
    (no units): 69.0
    (no units): 32.0
    Temperature: 17.5C
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    Shop #: WSC 06435 000 00000
    VCID: 45853FF57527
    1 Fault Found:
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    011 - Open Circuit - MIL ON
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000048
    VCID: 3A7F5C090CD9
    1 Fault Found:
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    008 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H53 0060
    Revision: 07S Serial number: AUZ2Z3C1484946
    Coding: 0001001
    VCID: EFE93D5D871B
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 168191 km
    Time Indication: 0
    Date: 2011.04.03
    Time: 16:46:06
    The airbag/crash sensor fault aparently popped up after a blue tooth kit was fitted if that helps any?
    The radiator fans run constantly so they are not jammed but them being on tells me that there is a problem.
    Apr 2011
    23
    Hi i can't help your problem, mine has just thrown up the air flow flap positioning motor and air quality sensor,sporadic 010-open or short to plus or ground. If i get any luck with what causes this i will let you know. I will keep checking your post also to see if anybody has helped you.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by readyrangers View Post
    I think Boydie will have this sorted by now mate - his post was 16 months ago !
    What fault code number was yours and have you checked Ross Tech ?
    Apr 2011
    23
    Hi Mike sorry about that it was showing at the top off the page never noticed the date. It has not taken me long in coming back again, i have got four faults now.
    17675 pump jet valve cylinder 3 regulation range exceeded p1267
    17678 pump jet valve cylinder 4 regulation range exceeded p1270
    I am now thinking it has to be faulty injectors this time as its the same code different fault, No lights coming on i just thought it was not running quite right today and these faults were there now.
    01274 Air flow flap positioning motor
    01592 Air quality sensor,sporadic 010- open or short to plus or ground.
    I had a quick look at ross tech 01592 is not on the list and the 01274 could be a faulty valve or blocked.
