AH FabricationsVolks Autos
    Mar 2011
    25
    Alternator Whine - so annoying
    Replaced my stereo for an aftermarket one, now i have alternator whine (which im guessing is worse as i have bose!)
    need to take it all out again and look for anything dodgy, only thing ive done "out of ordinary" is earth the handbrake wire (for obvious reasons ) and attached the 12v and 12/switchable straight to the incoming 12v constant wire from the car because there isnt a switchable 12 volt present.
    Done this loads of times so i dont think thats the reason, is it that the earth wire is just really crap (maybe ill have to run another one) anyone else have this, if not ill have to start playing around with filters etc... thought my days of alternator whine and ground loops were over!!!!
    Audi A3 05 Plate 2.0 TDI Sport!
    thanks in advance
    Fossie
    Rhubarb Triangle
    3,961
    NHN will know I'm sure !
    MTW
    MTW's Avatar
    Feb 2011
    212
    i too have this now after getting an aftermarket sound system, any ideas?
    Mar 2011
    25
    when i get a moment im going to use a new earth wire to the chassis and see if that helps as its doing my nut in!
    26,716
    Was about to say try a new ground & see what occurs, maybe worth asking Andymac in the Ice section.
