Chris NottVolks Autos
Results 1 to 12 of 12
    Feb 2011
    7
    Climate control problem
    My climate control wasn't very cold and felt a bit funny, so i got it serviced at an audi dealer on saturday, later after collecting the car i noticed the aircon now smelt nice, but wasn't cold at all, even worse than before! Was sweating like mad driving around on saturday even with it set to 16 and 'Lo'
    Now before i ring them and moan about it i want to make sure i am not being silly and have somehow turned the aircon off or something. I have the 'econ' off which as far as i am aware is correct, is there anything else that should be obviously on or off?
    Car is a 56 plate (i know something changed with the econ at some point, don't know when though)
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by XeNoN View Post
    Presumably you have the 'Auto' button switched on and the led is lit ?
    Feb 2011
    7
    Yes, Auto on with red light and econ off
    Fossie
    Rhubarb Triangle
    3,961
    In that case mate I should wing it back to them for another look !
    May 2010
    2,502
    this happened to my 2005/54. turned out the compressor was broken or something. cost 600 to put right . not trying to scare you or anything but if it's been gassed then it's not looking good!
    best of luck, let us know how you get on!
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    Fossie
    Rhubarb Triangle
    3,961
    XeNoN - thought you might be interested in this posted on another forum but by a member of this forum :-
    My 8p air-con has never been any good. when i bought the car it was 2.5 years old and i figured it needed a recharge so eventually i had a full air-con service inc disinfect etc when the car had its 35k mile major service. when i picked the car up the air-con was still useless and after asking about on AS.N i was told the 8p system was not up to much anyway so i forgot about it.....Fast forward too today and i thought, Summer is coming ( i live in a strange world of my own ) so put the car in the local Indy for a pressure and leak test on the air-con expecting to be forking out 500 for a compressor.. Turns out the system only had 100g or gas in it instead of 500g and now it blows freezing. Its never done that !!! the garage also put a dye in the gas to pin point any leaks but all seems well but he wants to check again in a week. Cost ? 90 inc vat. Audi charged me 2.5 times that and never got it to work.
    I dont know how they survive to be honest.
    May 2010
    2,502
    bugger you're making me wonder if Audi gassed mine up properly now!
    Feb 2011
    7
    Thanks for help, i double checked over everything to make sure it was set right, and it was. So i am now booked in again for them to have another look. I will not be happy if i need to shell out 600!
    Feb 2011
    7
    Bad news. Audi looked at it again yersturday, Air Con compressor needs to be replaced. Thats 800. They also found that the turbo over run valve needs replacing, which is another 150. I have had the car less than a month and am not very happy!
    26,721
    ebay is your friend.
    Feb 2011
    47
    Did you buy it from a dealer or private? How old is your car?
    Feb 2011
    7
    Quote Originally Posted by mrash View Post
    Dealer, and i have just spoken to them, they said they will fix it for free as I havn't had it very long!
