Badger5AH Fabrications
Page 7 of 7 FirstFirst 1234567
Results 241 to 266 of 266
Like Tree25Likes
Thread: My SPORT to S-LINE Conversion (Part No's, Prices & Tips included)...
  1. #241
    Oct 2012
    121
    TPS are great for parts - did me a good deal on a lot of these parts. E.g the grills were cheaper than I saw a pair used on Ebay.
    Just a quick one - the fog grills, in some of the original pics they look like they have no chrome surrounds but in some they do?
  3. #242
    tdi-man's Avatar
    Jul 2009
    1,612
    Got me bumper, fog lights, grills in the post and have the bonnet ready for coversion do I need any clips or anythink to fit the grill to the bumper.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
  4. #243
    TDI140's Avatar
    May 2011
    1,361
    Fog grills are stupid and dont grip bumper properly i snapped the lugs some how and now they are at risk of falling out lol, large middle grill just clips into bumper no new clips needed im pretty sure then you just use the top holding bolts to secure the top down
    tdi-man likes this.
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
  5. #244
    tdi-man's Avatar
    Jul 2009
    1,612
    cool ta yer already got the fog grills 1 clips in fine but the other wont will have a play with it before I fit bumper. also what do I need to do to get fog lights wired up ?
    thanks
  6. #245
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by tdi-man View Post
    Hard to remember now but I think it just clips in mostly. I think there are two or three screws along the top edge that secure it to your actual car though.... at the front of your engine bay.
  7. #246
    TDI140's Avatar
    May 2011
    1,361
    I bought ready make h7 to h11 adapterf from ebay and plugged straight into new fogs easiest way and took about 5 mins to fit but i have to wire in some error light resistors dur to having LED fog bulbs for the white colour look
  8. #247
    tdi-man's Avatar
    Jul 2009
    1,612
    right do I need to buy both of these for my conversion
    2 x S-line fog light plugs:
    Part number = 3D0 941 165A
    Cost = �14.50 for the pair
    Difficulty rating = 5
    (part no. 000 979 244E, cost 2 x �4.79)
    also any body got the part numbers for the 18 screws which hold the grill to the bumper
  9. #248
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    You definitely need the plugs because your existing sport's plugs won't fit.
    The wires you can get away with reusing your existing ones. It can be a bit hit and miss though so I'd recommend spending a tenner on new wires just in case you end up needing them.
    I can have a look in ETKA tonight to see if they are listed.
  10. #249
    tdi-man's Avatar
    Jul 2009
    1,612
    thanks
  11. #250
    TDI140's Avatar
    May 2011
    1,361
    I bought the plugs but didnt use them, i bought some off ebay plug and play ones, just type in H7 to H11 connectors and loads off them come up get some good quality ones so they are insulated well thats easiest way pal
  12. #251
    tdi-man's Avatar
    Jul 2009
    1,612
    got ebay number ?
  13. #252
    tdi-man's Avatar
    Jul 2009
    1,612
    searched h7 to h11 nothink came up
  14. #253
    TDI140's Avatar
    May 2011
    1,361
    Buy 2 h11 and 2 h7 wiring plugs from ebay and solder together and heat shrink and insulate around the solder then your good to go its pretty much the same as buying ready made ones also make sure you solder h7 to h11 not both same side lol or use juction box but recommend soldering
    tdi-man likes this.
  15. #254
    tdi-man's Avatar
    Jul 2009
    1,612
    just to confirm I need a H7 PLUG TO A H11 SOCKET ?
    thanks
  16. #255
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I think the screws you are talking about are part number N 908 974 01. You get 13 of them in a pack for about 50p. Audi will be able to confirm they are what you need, but looking at ETKA it looks like they are what you are after.
    The three screws that I mentioned that go at the top edge of the grille are part number N 910 702 01 (size M6x30). You'll get three in a pack... also about 50p. You'll definitely need these.
    Also, I wouldn't muck about getting fog plugs from ebay and soldering etc. Just get the proper ones from Audi as per the part number I gave you, it's not like they're expensive.
  17. #256
    tdi-man's Avatar
    Jul 2009
    1,612
    many thanks ads
    Ads likes this.
  18. #257
    TDI140's Avatar
    May 2011
    1,361
    H7 existing plug needs to go into a h7 female
    then you need to solder on a h11 male to go into the h11 bulbs for the s line fogs, even if you get it wrong you will only be about £15 out of pocket so dont have heart attack over it lol
  19. #258
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by TDI140 View Post
    Hold on. Unless I'm missing something very obvious here.... the actual real genuine kosher ones are only about £15 for the pair, so what's the point in doing an eBay bodge job for the same price?!
    Just ease off the existing plugs, fit the new ones, and hey presto... you've got working fog lights, for the same price as the eBay route... minus the fire hazard.
  20. #259
    TDI140's Avatar
    May 2011
    1,361
    No fire hazzard, upto him if he wants to cut the existing wires etc etc i just gave him an easy soloution the one i used as i didnt want to cut the existing plug
    plus electrical wite is copper wiring inside insulation so no fire hazzard pal upto him end of the day
  21. #260
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    The point is you don't have to cut the wires. Just ease them out and insert into the new plugs. Simple.
    I'm yet to speak to someone who hasn't managed it.
    I'm just trying to save him time and solder
  22. #261
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I'm still getting loads of PMs asking if I can help with sourcing bumpers...
    Sorry, my contact has long gone, so you're on your own guys.
    Good luck.
  23. #262
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Quote Originally Posted by Ads View Post
    Good luck.
    hi mate, sorry a bit off topic but I've seen you've moved from a3 to scirocco, and I'm going for that movement too. Just wondering if you could give me some help
    ( questions are in relative to a3)
    how is it to drive compared to the a3
    how is parking, is it harder/ easier?
    does the ACC make a difference?
    do you think it's a good upgrade, any regrets?
    cheers
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  24. #263
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by sliced View Post
    cheers
    No worries...
    The drive is much better than my A3. Braking, cornering, traction, everything is just much much better. Although that's to be expected as you're comparing an 'R' model to an A3.
    Performance is much better too, even though my A3 was remapped.
    A lot is made of the rear view in a scirocco being poor and that rear parking sensors are a must... I only slightly agree with this. The rear view is not great but it's enough to be able to reverse park with no problems after you get used to it. Parking sensors would obviously make it easier but they are definitely nowhere near "a must" for any half decent parker.
    ACC works nicely. In comfort mode the steering becomes lighter and suspension softer, although still as firm as say an A3 sport, maybe slightly less firm. Normal mode is more somewhere between sport and s-line I'd say. Sport mode is very firm and you'd only want to use this over smooth surfaces. The steering firms up nicely too and throttle response gets sharper. Again, these are all relative to the R.
    For the GT they say that the sport mode is similar to the R's normal mode, and the GT's normal mode is similar to the R's comfort mode.
    I think the scirocco is a worthwhile upgrade. You get a lot more as standard, so depending on how your A3 is spec'd you could end up with a lot more toys.
    Like most of us, I like people liking my car and the scirocco gets a lot of nice attention, with people pulling up next to me asking what it is etc etc.
    Which engine/model scirocco are you looking to get? Also which year? There are a few changes to be aware of if going for a GT... engine power increase on the 2.0tsi, white dials/DIS around late 2009, plus a few other bits.
  25. #264
    sliced's Avatar
    Jun 2012
    1,217
    Thanks for the advice and help.
    im going from a 2.0 tdi a3 to a 2.0 tdi scirocco gt 2009, hopefully in white :D
  26. #265
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Have a look at this link. Loads of info on model year changes, etc...
    http://www.sciroccocentral.co.uk/roc...al_Information
  27. #266
    a31.6sport's Avatar
    Mar 2012
    A, A
    7
    Can you confirm what year front s line bumper you went for please I have 2006 sport
