Results 1 to 7 of 7
Thread: fan faulty ???
    tdi-man's Avatar
    Jul 2009
    1,588
    fan faulty ???
    18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    got this fault code today any ideas ??
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Fossie
    Rhubarb Triangle
    3,961
    Basically it's exactly what it says !!
    18359/P1951/006481 - Ross-Tech Wiki
    Jun 2010
    Coventry/Warwickshire
    2,074
    I had this and it turned out the water pipe as you look into the engine on the right hand side was fouling the fan .Audi had recently replaced the cam belt and left it like that ,Luckily i checked it with VAG COM and caught it before it split the water pipe .It was stopping the fan spinning because the clip holding the pipe on was not in the correct position ! .Who knows what would have happened if i had gone on a long drive ...HTH.
    tdi-man's Avatar
    Jul 2009
    1,588
    had this fault code again .
    wonder if fans bust ?
    am checking every day know ?
    any way to test fan 2 ?
    Aug 2006
    72
    You can test the fan electrically using the 'output test' button on vagcom when logged in to the engine or aircon control module.
    It will be the smaller of the two fans, try to spin it by hand, probably stiff due to dry bearings. You can't dismantle the
    motor as it pressed together.
    Scott.
    (8P)A3 2.0 TDI Sport-Dolphin Grey-
    1983 (DAC)Talbot Sunbeam Lotus - Weekend Toy.
    tdi-man's Avatar
    Jul 2009
    1,588
    it spins ok wil check in vag com tomo
    tdi-man's Avatar
    Jul 2009
    1,588
    Logged onto 01 engine and went into output tests and there was 1 in there for fan 1 but not fan 2
