AH FabricationsVolks Autos
    Apr 2011
    Unhappy SYMPHONY LL RADIO KEEPS GOING INTO 'SAFE' MODE
    Hi everyone,
    Does anyone know what is causing my radio (Symphony ll A3 2004) to keep going into 'SAFE' mode everytime I start the car. I am basically having to enter the code everytime I use the car, have never entered the code incorrectly, and yesterday had a new battery fitted as old one died. I did recently have a Parrot Handsfree system wired up a few days ago, so the radio was removed for fitting, but the handfree is working perfectly, even with Radio off. Could this still be the cause? Or does it sound like a fuse problem? But the radio works fine upon entering the code
    Fossie
    Rhubarb Triangle
    3,961
    Doesn't sound like a fuse because everything actually works !
    Sounds like the radio is not storing the code that you enter for some reason but I'm afraid I can't offer a solution!
    After you have entered the code are you sure there isn't a button to press to save it ?
