Volks AutosEM Tuning
Thread: Fault codes
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Fault codes
    Anyone any ideas on these thanks..
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000647973
    Coding: 058C4F01A0141000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7168A003E3
    Part No: 8P2 955 119 C
    Component: Wischer WWS Audi350 0180
    Coding: 16711696
    Shop #: WSC 00000
    4 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    004 - No Signal/Communication - Intermittent
    01320 - Control Module for Climatronic (J255)
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    00466 - Control Module for Steering Column Electronics (J527)
    Fossie
    Rhubarb Triangle
    3,961
    Good question mate !
    Maybe someone from RossTech will follow up ? Bear the Bruce normally monitors VCDS area of the forum to blast non-conformers !!
    Try posting on the VCDS bit and see if it works !!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Cheers mike, why do i always get the codes not listed on the VCDS site......... everything seems to work ok but the Aircon packed up years ago. Its going in on Monday so expecting a huge bill !!
    I did clear the codes twice but they come straight back. Some times " intermittent" can be low voltage so tried again with engine running and still the same.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by paddy View Post
    Me too !
    That seems to happen often these days ! Now I'm fully registered perhaps I could ask the questions !!!
