EM TuningAH Fabrications
Results 1 to 11 of 11
    Jun 2010
    21
    Smile Changing flywheel and clutch luk or sachs can either fit? Quick answer please
    Hi all.
    Got a great deal on a luk flywheel and clutch.
    Thing is tho I have been told it could be sachs or luk but the only way to tell is to remove the gearbox.
    Can I fit a luk kit if the car has a sachs? As I would be replacing everything and not crossing parts over.
    I hope someone can give me some heads up as its getting done tomorrow hopefully.
    Thanks all.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    what car is it going on?
    just to give you an idea, the original clutch & flywheel on my car was a LUK, it now has a sachs clutch with a LUK flywheel so you shouldnt have a problem
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Jun 2010
    21
    2004 54 plate. 2.0 tdi face lift.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    should be fine (as long as the parts are for a 2.0 tdi A3), reason i asked is if it was something like an S3 you dont want to be putting an LUK in as they cant handle the power
    Jun 2010
    21
    Yeah parts I got are for a 2.0 tdi 2004 - on.
    The car has a BKD engine.
    Got the clutch kit and flywheel brand new for 160 quid + postage
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by danonline View Post
    should be good to go
    160... thats less then i paid for just my flywheel!
    Jun 2010
    21
    I know I got a bargain I think
    Jun 2010
    21
    Thanks for your help.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    no worries & yea sounds like you did!
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    634
    For reference here is the differences(you can spot these by looking through the inspection hole on top of the gearbox) :
    Jun 2010
    21
    tried to see where it is. Can find the place to see?
