Sky InsuranceEM Tuning
    Mar 2011
    seafoam engine cleaner
    Hi all.
    Just bought a can of seafoam engine cleaner and im going to use it only in the fuel tank. Just wondering if anyone else has used it and how much to use?
    On the site it tella u how much seafoam to use per diesel...but not how much u should use altogether. Ive heard a whole tank of fuel then how ever many litres that is to just add the seafoam up? Car is a a3 2.0 diesel turbo 2005 with 120,000 on the clock.
    Thanks for any help in advance
    Feb 2011
    Leeds
    149
    I've never heard of seafoam, my ignorance I guess.. I normally run Forte in mine, seems to work a treat. Can you tell me where I can get get soe from to try
    antmax7's Avatar
    sheffield
    300
    hi on the bottle it recommends you use 1/3 of a bottle per 70ltr of fuel from memory i have used it on my van it works
    why are you not using it in vac system also????
    and in oil?????
    the whole point it is a full engine system treatment not just a fuel system treatment.
    Apr 2012
    I totally agree with antmax7.I've used it on two of my A4 1.8T and going to use it on my VRS soon(just ordered it).For me it works wonders.I always use 1 can and split it in 3(fuel tank,vacuum lines and engine).Usualy run with seafoam in the engine for good 50-60 miles.Go for it,mate!
