AH FabricationsVolks Autos
Results 1 to 13 of 13
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    boost problems again
    hi all,
    i know its got loads of threads about it but i have done everything posible to cure it
    basically i have a 2005 a3 sport with about 87,000 motorway miles,
    ive had few boost problems, first of all i have reaplced the fuel sensor and coolant bottle because the fault was reading on vagcom,
    aswell as that the turbo was going into limp mode, so checked under the engine bay cover, seals on boost pipes leaking, so replaced those, no leaks now but i did fing abit of oil around the turbo and egr vlave,
    when driving the car im getting a whistling noise when i accelerate and the when i take my foot off the accelerartor it makes like a dump valve noise, it also does this if i rev the engine when im stationary, also the car seems to have lost abit of power and feels like it struggling when the turbo kicks in when driving
    so im thinking maybe the veins on turbo are clooged up, or could it be a dodgy maf sensore or egr vale?
    any help would be very greatful, as i dont want to go and put a new turbo in if it not that
    thanks
    Fossie
    Rhubarb Triangle
    3,961
    Sorry Jord but it sounds like turbo ! Have you scanned it for faults ?
    As you have replaced boost pipe seals etc. and it still makes the noise then turbo is about all that's left.
    You could strip it and clean it if you wanted but I went for a recon turbo when I had the same symptoms.
    26,762
    Change maf anyway if its original at 90k, can only help going forward, have you cleaned the egr out, have you checked the intake mainfold flap as internal teeth break given plastic, all things to check before condemning turbo, but yes at 90k turbo may indeed be caked internally.
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    Cheers, it's weird how it's still boosting ok though, but it gets to just over 3k revs in fourth gear and feels like it's gonna pop, like I can feel the turbo pressurising ready to blow, as for egr valve I havnt cleaned it out yet but im thinking I might go for a blanking egr valve? But I've heard mixed reviews, also the egr solenoid has a slight buzz, I had it checked when my fuel sensor was playing up and didn't scan up then,
    I think I might try n get it on the ramps tomorrow and have a closer look, it's going into a local vag specialist on Monday, just don't want to Gond it's something stupid that I could of fixed and end up costing me a fortune
    Anymore help would be much appreciated
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    Dec 2010
    110
    My 2005 TDI A3 also makes the exact same turbo noise, though it drives fine and boosts OK throughout the rev range. It did go into limp mode a month or so ago, but it hasn't repeated it since then, my VAG-COM reported the limp mode being an overboost error, but that's the only error it showed and it hasn't happened since.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by evilbane View Post
    Keep your fingers crossed !!!
    Dec 2010
    110
    I have been since it happened, but so far so good........
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    Car fixed, a paddle before the turbo was stuck, feels like a new car 
    26,762
    Care to expand on that a little as in which part caused your issue as paddle doesnt help allot.
    Jord's Avatar
    Dec 2010
    Ellesmere port
    269
    I took it do local vag tuner, can't really remember what it was, but it was something just before the turbo that was half jammed open, so he's freed it and clean all the crap and he said give a good boost on motorway to clear sediment, got it on motorway planted my foot, huge black soot cloud, and now it drives like a dream
    I will try and find out what part it was actually called
    26,762
    Yes I'd be interested to know what socalled paddle he freed.
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    +1
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
