Page 1 of 5 12345 LastLast
Results 1 to 40 of 168
    Apr 2010
    182
    a3 tdi multiple problems!! (doing my head in now please help)
    hi guys put a few posts about my gf's 2004 audi a3 tdi, firstly it is juddering when stationary, as suggested on here the EGR valve has been cleaned out and all pipes also cleaned out and still hasn't made much difference but the car does run a bit smoother. so any other tips we could try?
    it had an MOT a few weeks ago and the guy said there pas two fault codes on there....
    engine coolant sensor on radiator outlet C983 signal too high: P2185
    now after a quick google we have replaced the coolant sensor on the right side of the engine block but cant find the other sensor as there is apparently another one? if anyone could point me in the right direction of this id be grateful so i can replace it.
    the fans are also coming on everytime the car runs within a few minutes of running they are at full spin and dont stop for a few minutes after the car is turned off, i read about fans not working so i checked and only one of them is running (passenger side) could anyone shed any more light on this please?
    last but not least im sure, the other fault code off the garage was...
    exhaust gas temp sensor 2 bank 2 g449 electrical P1961
    spoke to a guy at ford and he said its a lamba sensor?? iv looked on the car and cant find any
    again any help/ info would be gratefully received as its starting to really annoy me now!
    thanks
    Dan
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    The other one is on the return from the rad down near the thermostat, I know as I need to change my one, I think that you can only do that one on a ramp.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Apr 2010
    182
    ok cheers could i see it with the undertray off then? anyone got a diagram to guide me what im looking for?
    cheers
    Fossie
    Rhubarb Triangle
    3,969
    I don't think the BKD engine has a Lambda sensor has it ?
    Apr 2010
    182
    ive managed to find the other temp sensor....man it looks a pig to replace! lol
    iv been told they dont either but if they dont then why is it giving me this fault or does it mean something else?
    thanks
    Fossie
    Rhubarb Triangle
    3,969
    Those two fault codes do not appear on the Ross-Tech list.
    Think you need to scan it with VCDS to get more info.
    Wozski's Avatar
    480
    how do you clean the egr valve?
    and where is it lol
    Apr 2010
    149
    juddering can occur when your flywheel is on its way out, however you have fault codes so check them first.
    Apr 2010
    182
    yeah as i said iv found the second sensor so ill change the one at the front of the engine but cant get my ehad around the fault code....
    exhaust gas temp sensor 2 bank 2 g449 . electrical. P1961
    Jun 2010
    Coventry/Warwickshire
    2,074
    Quote Originally Posted by gizm0 View Post
    My car judders on tickover ,I hope its not the flywheel its doing my head in when im stationary in traffic .Its like being in a vibrating chair .
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Mine judders on tickover sometimes, you can see the rev needle fluctuating by about 100rpm. Doesnt always do it though so Im assuming its not the flywheel?
    ste
    reverse gear
    west midlands
    121
    hi guys, that juddering will be the down to the dual mass flywheel wearing. Its turning into another common fault now these cars are ageing. fit a solid flywheel, they are better.
    Apr 2010
    149
    if you put the clutch in n juddering stops its the flywheel, otherwise its fine
    Jun 2010
    2,074
    Nope mines the same when the clutch is depressed.sorry to highjack .Could it be the injector fault its smooth rapid and no other faults
    tdi-man's Avatar
    Jul 2009
    1,612
    mine does it more so when warm and i have changed just about every thing. if you put the air con on does it stop ?
    i think that its lack of fuel on tick over which is aN ecu fault ? as when i put air con on it dumps more fuel in and idles fine
    thinking of getting my ecu tested before my remap....
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Apr 2010
    182
    Well when the clutch is pressed it doesn't make any difference, so its not the flywheel so for now im going to change the other temp sensor and go from there but can anyone shed anymore light on the lamb fault code please?
    Fossie
    Rhubarb Triangle
    3,969
    Sorry mate - can't believe those fault codes. You need to have it scanned on VCDS.
    Can you find someone near you who could help ? List of members prepared to help and whereabouts they are is shown on NHN signature page.
    I still don't think there is a Lambda sensor on the BKD engine. It is a BKD engine isn't it >
    Apr 2010
    182
    2bh I don't know anything about these engines too many sensors etc for my liking lol what do you mean bkd?
    The guy who read the codes said he done it on a propped computer n he wrote it down for me word for word....
    Fossie
    Rhubarb Triangle
    3,969
    BKD is the engine code for a 2.0 litre 140bhp direct injection turbo diesel engine. The inside front cover of the service book will confirm and if that's not available the same sticker is in the spare wheel well. The 140bhp engine does not have a lambda sensor but the 170 bhp engine does.
    I dare say the guy had a 'proper' computer but the car needs scanning with VCDS software to get the correct diagnosis.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    """"""""""""""""""spoke to a guy at ford and he said its a lamba sensor??""""""""""""""""""""""""""""""""2
    you said it all there
    May 2010
    London
    334
    The juddering could be the intake manifold flap, had this on mine, replaced it and now its gone. When you turn the engine off if there's a shudder then that usually points to a faulty/failing intake manifold flap. You should not feel any vibrations when turning the car off.
    27,097
    There is no lambda sensor on the bkd engine iirc, I have 2 of the buggers.
    Yeah front coolant sensor requires small hands for sure or large ones that require broken fingers
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    547
    ive had new clutch and flywheel and cleaned the egr valve and i still got judder ive also noticed mine does it when at lights when parked uphill
    i was wondering engine mounts might be the problem for me
    S3 8L ming blue westys old car shed loads of mods
    Feb 2007
    Hampshire
    1,654
    Perhaps it is the lift pump in the tank if it is when uphill.
    Paul
    VCDS HEX-USB+CAN
    Fossie
    Rhubarb Triangle
    3,969
    Do we need to consider the injector wiring loom problem that keeps cropping up ?
    Jun 2010
    2,074
    This is my line of thought.
  28. #27
    Apr 2010
    182
    sorry forgot to mention that she's had the injector loom changed as someone suggested this before but made no difference, shes also had the fuel filter changed because it was black and all sludged up and had the system flushed....
  29. #28
    Fossie
    Rhubarb Triangle
    3,969
    Is it a BKD engine code ?
  30. #29
    Apr 2010
    182
    Not sure at the min because the gf has the car at work but I'll look later n report back
  31. #30
    tdi-man's Avatar
    Jul 2009
    1,612
    ANY BODY which has a rough idle when warm can u please do the following.
    check with vag com the injectors the amount of fuel which is going in i have found the more fuel goes in when cold or air con in the amount is 3mg - 5mg but once warm the faul mg drops to 1.5 -2.5 which is the probelm
  32. #31
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by tdi-man View Post
    Are you saying that you can adjust the amount of fuel going through the injectors using VCDS ?
  33. #32
    807
    No he is saying comparing measuring blocks when cold or aircon on vs measuring blocks when warm.
  34. #33
    tdi-man's Avatar
    Jul 2009
    1,612
    no i wish u could adjust it ....
    you have to check measuring blocks not sure which ones as sold me vag com till i get another next week.
    one of them will show you the total injected fuel going in and another will show you how much each injector is pushing in i might have a print scrren pic on laptop will check later
  35. #34
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by benr View Post
    And if the results are not in accordance with normal parameters can alterations be made with VCDS ?
    He said 'please do the following' intimating that something could be done about it !
    If adjustments aren't possible, how can the problem be corrected ?
  36. #35
    Dec 2010
    31
    Mine judders and I have VCDS I will plug it in and try to make it judder - only does it occasionally though!
    Highly annoying and weird!
    Will try tonight!
  37. #36
    tdi-man's Avatar
    Jul 2009
    1,612
    measuring block 01 shows total injection quantity i have found it has to be 3.0 min or ticks over rough..
    measuring block 013 shows each injector and amount of fuel going in ...
    when cold total injection quantity is fine but once warm may drop to 1.5 - 2.5
    also when idles rough put air con on and see what total quantity goes up to.
  38. #37
    807
    He actually said
    "please do the following.
    check with vag com.... "
  39. #38
    tdi-man's Avatar
    Jul 2009
    1,612
    check first and report back...i believe the fueling can be turned up on idle by a mapper which is my next step
    use to do this on my pd 130 mk 4
  40. #39
    Fossie
    Rhubarb Triangle
    3,969
    He actually said
    Yes, I realise that, but if, after checking, the results show it's not within the design parameters then what I was getting at is what can be done about it ?
    No point in finding something wrong (ish) and being unable to do anything about it without having modifications done ?
    I was really trying to find what the solution is to the problem.
  41. #40
    tdi-man's Avatar
    Jul 2009
    1,612
    there are many faults that can cause judder at idle ive replaced just about all of them i think..
