Chris NottJMB Retrofits
    Jun 2010
    Coventry/Warwickshire
    2,074
    Sudden Water leak any ideas please ?
    I have a small water leak from the right hand side of my car( looking at the head lights) its the oposite side from water pump etc .That was changed when they changed the cam belt etc and alls good around that area .I have removed the engine cover from underneath and cannot see any corrosion or damage .Is there any known Leaks/faults seals etc .I have phoned the warantee place, WMS who are saying if its a seal they will not pay hence me having a look .They have also stated that i can not use Audi/main dealers etc .Any one have any ideas .Its a 2007 2.0 tdi sport.
    Fossie
    Rhubarb Triangle
    3,969
    If you mean passenger side front then radiator leaks are a common fault in that bottom corner
    Jun 2010
    2,074
    Thanks for the reply Mike .I cannot see any corrosion anywhere must be just poorly put together .Going to radweld it before i try to get it resolved using the warantee (looks like a crappy warrantee )
    Fossie
    Rhubarb Triangle
    3,969
    Try K-Seal. It's about 7 a bottle and you just pour it into the header bottle without having to pre-mix.
    Jun 2010
    2,074
    Cheers Mike i will try that then .
