Volks AutosMonster Motorsport
Results 1 to 20 of 20
    Jan 2005
    50
    ipod with concert II
    Hi guys, its my first post so firstly hello to everyone.
    I ordered my A3 2.0 TDI on the 06/01/2005......already counting down the days! I am wanting to fix an Ipod via the dension Ice link but want to fit it in the glove compartment. Does anyone know if the concert stereo can control the ipod i.e. change tracks etc
    Also I have read in a couple of posts that Audi have contacted people to tell them they are building the car.....Do they contact everyone?
    Thanks guys, gonna go to bed and then I can tick another day of the calendar.
    Jan 2005
    Ireland
    17
    Re: ipod with concert II
    i'm intending to install an ice>Link in the next couple of weeks... i'll post some pics on here when i'm done.
    in the meantime check out iPodLounge: http://www.ipodlounge.com, loads of good info on the iPod in general, check out the "Gear" forum for in-car info.
    Dec 2004
    Luxembourg
    161
    It's the space directly in front of the gear stick where the ash tray is. I think the base is rubber so their is minimal movement from the iPod. At the moment I'm actually quite happy to leave it there as it's out of sight and easy to access. My original plan was to mount it in the glovebox but I'm considering this option less and less each day. I ordered the cable version and what I have done is put it into the original iPod belt clip case upside down so i can plug in the cable. It's protected quite well.
    Oct 2004
    London
    109
    Here's another tip. If you want to dashboard mount it both Carphone Warehouse and Unicar do it. Unicar seems the better option IMHO. They will come to you at no extra charge (London metro at least) and complete the install for 50 including VAT. For an extra 16 they will supply the dashboard mount bracket which prevents you having to actually drill holes in the dash and potentially devalue the car. I'm sure you could get the bracket more cheaply. My Sportback is due for delivery on the 26th of Jan so I will be ordering in iceLink and having it installed in the next few weeks. I'll try to remember to post once I have had it installed and give some feedback for you guys.
    Nov 2004
    St. Albans
    61
    found this website.
    http://www.ihavetohave.it
    I'm going for:
    Audi headunit removal keys (7.99)
    Bracket (the one that clips on rather than drilling hole) (15)
    ICElink (99.99)
    I'm gonna have a go at doing it myself, but was wandering as to how to feed the cable to the rear of the headunit- any ideas?
    Nov 2004
    St. Albans
    61
    and I found this on an excellent forum for ipods called http://www.ipodlounge.com
    http://www.ipodlounge.com/forums/sho...highlight=audi
    I was gonna get a pro to fit it, but it looks p1ss easy- so I'm gonna try it myself. The pics in the link look very tidy! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Nov 2004
    35
    [ QUOTE ]
    tboy said:
    found this website.
    I'm going for:
    ICElink (99.99)
    [/ QUOTE ]
    I'll try and take a look at mine later to see where the cable goes.... might try and take a pic too...
    Nov 2004
    St. Albans
    61
    right- I've managed to install the Dension myself, don't bother with paying 50+ for it- it really is a piece of p1ss, and i've absolutely no knowledge of ICE installs or anything remotely similar- I've never even changed the fuse on a plug!!!
    However!!! I'm trying to perform the software update, and seem to be struggling, any advice? My ipod is currently on release 2.02, and I wanna get it up to 2.04. Also, is anyone else experiencing odd behaviour when skipping through tracks?
    Jan 2005
    Ireland
    17
    tboy, you talking about updating the firmware on the iPod itself? just download the updater from here:
    http://www.apple.com/ipod/download/
    plug the iPod into your Mac/PC and run the updater, usually works fine for me.
    does the Concert II show the track/artist info on its display?
    Nov 2004
    35
    Unfortunately not, only on the iPod itself.
    The only weird behavior seems to be if I try and do too much too quickly, it seems to confuse the iPod and/or head unit. For example, if I select an album, then hit play, then skip to the next track from the head unit immediately, sometimes it just hangs for a second or two, then goes back to the main menu on the iPod. Then it'll just drop straight back to the main menu whenever I try and play a track. The only solution is to switch off the iPod and turn off the head unit, then turn it all back on again.
    It only does it very occasionally, and is fine as long as I don't rush it!
    Nov 2004
    St. Albans
    61
    [ QUOTE ]
    Mac1 said:
    Hi all, i'm after a bit of help. I've fitted an icelink plus to my concert II but don't get any power at all to the cradle. What is this loose black wire as i did'nt see one ? Any help much appreciated
    [/ QUOTE ]
    if you pull it all out at the back, the loom of wires connected to the harness that goes into the back of the HU should have a black cable, which should be loose at one end. You should attach this to the bare metal anywhere on the back/top of the HU.
    Jan 2005
    6
    [ QUOTE ]
    [/ QUOTE ]
    IPod lounge has some good info but lots of the same stuff repeated over and over. I have a crx track car - I noticed on the Honda forums some guys recommend the neo ion www.mp3yourcar.com so I checked them out and bought one.
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    I got the Itrip FM transmitter for mine. Its no way as good as the hardwired solution but ok if you use the IPod in the car occasionally. Finding a clear fm station can take a while but the high end seems to be better (104fm +).
    I already have an MP3 sony changer in the glovebox so this was just for fun really.
    Jan 2005
    Ireland
    17
    Yeah I have the iTrip also, and found it was fine for pootling around town when you can keep it on the one frequency, but for cross-country trips I kept getting drowned out by local radio stations. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    May 2004
    Yorkshire
    7
    I use the itrip I have found the best frequency is 87.5, you have to add this from the griffin site. It is one of the few FM frequencies not to be sold in the UK.
    Jan 2005
    Ireland
    17
    [ QUOTE ]
    [/ QUOTE ]
    Yep 87.5 was the frequency I used most often, but in Ireland, it sometimes gets drowned out by RTE [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Don't get me wrong, iTrip is very handy, but it's never going to match a wired solution.
    imported_ajh
    [ QUOTE ]
    [/ QUOTE ]
    Were there enough space behind the HU for the cable to go to the ash tray? Is the installation really plug-and-play sort of (haven't really installed anything before) or is there possibility to mess it up? Is there any good installation guides around?
    Garth_S3's Avatar
    Jan 2005
    159
    Don't use the FM broadcast things, they're rubbish. Get yourself one of these like me: http://www.essentialipod.co.uk/produ...d=1480&xSec=23
    Superb product [img]/ubbthreads/images/graemlins/smile.gif[/img] Got mine fitted in the glovebox so the ipod is hidden away and fully controlled by the hu.
    wilko's Avatar
    Top Gear
    Feb 2005
    Nottingham (UK)
    724
    How did you mount it in the glove box? Was it easy to install?
    Garth_S3's Avatar
    Jan 2005
    159
    [ QUOTE ]
    [/ QUOTE ]
    Really easy, yes.
    I've mounted it to the right hand side at the top, just on the side of the airbag switch.
    Give me your email address, and I'll email you some photos that I took while installing it.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
