The door cards are different depending on if you have the interior lighting pack fitted or not.
If you don't, which most of them don't, then at the bottom of the door card there will be a rectangle shaped indent where thenouddle light is meant to fit, also at the end of the door card there will be a red plastic reflector which is just a red blank and has no bulb behind it.
Cars which have the interior lighting pack will have the puddle light and the red warning lights installed along with the led on the door handle.
These lights including the door handle led can be retro fitted (check out my link in my sig).
