AH FabricationsEM Tuning
Thread: ECU PART NUMBER
    tdi-man's Avatar
    Jul 2009
    1,612
    ECU PART NUMBER
    ANY BODY KNOW HOW TO GET THE MAIN ECU PART NUMBER BY USING VAG COM - VCD'S
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Fossie
    Rhubarb Triangle
    3,969
    What do you mean by 'main ecu' ?
    If you click the auto scan button and on the next page select vehicle and hit 'go' it will scan all installed modules.
    If you then save the scan you will be able to read all the details of all the modules.
    tdi-man's Avatar
    Jul 2009
    1,612
    OH yer doh will that give me the bosch number ?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by tdi-man View Post
    Yep - should do ! If it's the engine module you mean just select that from the menu and don't bother with the rest !
