Sky InsuranceVolks Autos
Results 1 to 10 of 10
    HIGGINS's Avatar
    Mar 2010
    520
    Adjusting Xenon Headlights
    I have retrofitted xenon headlights into my car without any auto leveling fitted.
    The headlights are really low and are only shining right infront of my car and i cant see a thing.
    How do i manually adjust them? I have searched but cant find anything that has helped. I have also looked at the lights and i cant find anything that adjusts them
    Can anyone help?
    Selling MY11 rear lights, message me for a price
    Dec 2009
    155
    There should be two White adjusters on each headlight. One for main beam one for high beam. They need an Allan key
    As far as I remember for the dipped beam if u look at the headlights from above u should see it down through a little gap. Can't remember which way to turn to raise them. Park against a wall preferably with bricks and lines so u can see them rise.
    HIGGINS's Avatar
    Mar 2010
    520
    I parked the car against a brick wall like you said and i played with the white adjusters and they just were spinning freely with 0 difference :S
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Off topic I know but..............what rims you running now bro?
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Dec 2009
    155
    Quote Originally Posted by shiggins92 View Post
    That's defo how mine adjusted. Maybe they are not getting a bite or something but I'm sure they didn't really feel like they were moving much when I did it hence why I said do it infront of a wall. it took quite a lot of turning.
    HIGGINS's Avatar
    Mar 2010
    520
    Quote Originally Posted by N8 View Post
    VMR VB3's Love your car btw buddy...it really is in its own class
    Quote Originally Posted by latta1989 View Post
    Hmm well i was only moving them a tiny bit at a time as i couldnt get a good bite as the allon key wasnt long enough but i think you can also use a screw driver on them so might have another go tomorrow night as im in manchester for a few days from wednesday and i need it fixing :P
    tdi-man's Avatar
    Jul 2009
    1,587
    you will need to take them out and fit to a car that has them fitted as standard set them to MOT mode in vag com which locks them into the correct height them remove them and refit to your car . then take to mot station and adjust with the lugs for fine tuneing....
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    The Autolevelling system just controls the standard levelling motors, which are adjusted with the 0-1-2-3 control inside the car on normal models.
    As long as this motor is connected properly and set to 0, its exactly the same as having the xenons put into test mode as described above.
    TD5 Land Rover Defender build
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Any pics? Update your sig! Did you sell the Helios? Cheers bro, its getting there!
    HIGGINS's Avatar
    Mar 2010
    520
    I didnt know you could fit the xenons to your interior leveling 'switch'. How do i do this?
    Nop no pics, will be in around 2 weeks I know the sig is around 6 month old now haha
    Also yes i sold them around 6 weeks ago haha
    Your car will never be 'there' it doesnt stop
