AH FabricationsJMB Retrofits
Results 1 to 7 of 7
Thread: 04 tdi a3 2.0
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    04 tdi a3 2.0
    Hi I've got a a3 tdi 2.0
    04
    & so has my friend
    He had told me to ask
    He had his mot & after he seemed to think his engine has got louder on tickover?
    I've put my car next to his & it is louder but fine when moving.
    You can hear tickover in the car unlike mine
    Now what could this be? Any ideas??
    Fossie
    Rhubarb Triangle
    3,969
    Please do not use text speak !
    Banana Armour
    Aug 2009
    171
    Sorry mike!
    Changed accordingly. On my iPhone is my reason why I used text talk. Help needed. Regards
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    I know MOT is different here, but was there any work carried out on the car?
    Moved to the Darkside click below:
    Fossie
    Rhubarb Triangle
    3,969
    As far as I'm aware the only thing they do for an MOT is run the engine for emissions purposes (apart from all the other checks obviously !).
    There should be no reason why the car sounds any different.
    Tickover is much noisier when the car is cold so could this be the reason ?
    Banana Armour
    Aug 2009
    171
    Passed first time. No advisorys.
    Both with warm engines. 90 degree engines.
    Think he has just had a coolant change mind & said it just sits below 90 Mark.
    27,129
    That maybe a better mix of coolant, as people add all kinds of coolant to top up, I use a 50/50 mix & always sticks at 90 even in 40-50 heat in italy.
    For me its just his hearing as unless they did anyother work to the car whilst on mot, then nothing they would touch to affect the car, unless they're unscrupulous & caused an issue to get more work, only you know the test station to know what the likeliness of that is.
