Hope someone can help me with this.
Got the right dipped malfunction light come up on the dash the other day, so thought the bulb had blown. Changed the bulb, still no difference.
Tried the bulb from the other side of the car as I knew this one worked, still malfuntioning?
Done a scan with vagcom and got this error code from central electrics:
Sunday,20,March,2011,14:32:00:46052
VCDS Version: Release 10.6.2
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Control Module Part Number: 8P0 907 279 K HW: 8P0 907 279 K
Component and/or Version: Bordnetz-SG H54 2501
Software Coding: AD880F21B01410004F0000003000000000095E175C01020E000000000000
Work Shop Code: WSC 06314 000 08192
Additional Info: 8P2955119E Wischer AU350 H01 0130
VCID: 458534B475DD
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 73955 km
Time Indication: 0
Date: 2011.03.18
Time: 18:52:00
Freeze Frame:
ON
Voltage: 13.60 V
ON
ON
OFF
OFF
OFF
Hope someone can shed some light on what is wrong with the car & what I need to do in order to fix it.
Thanks....
VCID: 458534B475DD
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 73955 km
Time Indication: 0
Date: 2011.03.18
Time: 18:52:00
Freeze Frame:
ON
Voltage: 13.60 V
ON
ON
OFF
OFF
OFF
Thanks....
