Advice needed on 2005 Audi A3 2.0 TDI 140 bhp Turbo noise
Cloth ears
Sheffield
Website
www.germancarspares.com
Hi
I've just purchased a second hand turbo for my A3 after being told by the garage that my previous turbo was not pressuring up sufficiently as the car was sluggish and engine management light was on so now I have had this one fitted there is a big difference in the pulling power but every time I put my foot down you can hear like a screeching whistling noise as soon as I take the foot off it disappears i have been told by the garage that it seems to be a slight leak from one of the seals on it, does any one have any suggestions and also does any one know any one who reconditions the turbo unit in Sheffield.
He also mentioned that on the old turbo the fan was not spinning but he has managed to free it and it spins fine maybe that was the problem on the old unit, he also made me change the vacuum control unit that was on the bulk head black box with pipes coming out as he said when he bypassed it it ran better.
I have the same noise ......Don't know if my turbo is going or not....:sadlike:
Check intercooler pipes, the seals in them are common. You'd be wasting your money on a vnt recon. Best buy new
Just did a Vagcom scan and it came up wit this :
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 000 - - - Intermittent
Freeze Frame:
RPM: 819 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00000111
Temperature: 84.6°C
Duty Cycle: 9.6 %
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 000 - -
Freeze Frame:
RPM: 1932 /min
Torque: 172.0 Nm
Speed: 48.0 km/h
Load: 41.2 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 36.9°C
Temperature: 34.2°C
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition) I think it's something to do with this ....as it went into limp mode......
P0234 - 000 - -
Freeze Frame:
RPM: 2520 /min
Torque: 276.0 Nm
Speed: 110.0 km/h
Load: 51.4 %
Voltage: 14.44 V
Bin. Bits: 00000000
Absolute Pres.: 2019.6 mbar
Absolute Pres.: 2590.8 mbar
Readiness: 0 0 0 0 0
Those codes I also had when my turbo was about to blow up, the vanes are probably caked, I wouldnt drive it until turbo is checked.
