Results 1 to 16 of 16
Thread: Clutch slips
    Mar 2011
    6
    Clutch slips
    Clutch is just starting to slip on my s3 under hard acceleration, only had the car a day, the dealer is willing to get it done, but not by audi, he wants me to book it into halfords autocentre, what do you think, please help..
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    This sounds like nonsense from the dealer.....what reason has he given for not doing it in their own workshop?
    Either way,make sure they fit something decent,like the Sachs clutch.
    Mar 2011
    6
    Sorry just a car dealer
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    Quote Originally Posted by Racheluk View Post
    As in not an Audi main dealer?
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    You've only just got the car, so I think it's reasonable to point out that the car had the fault when you got it.
    Therefore, make sure you're completely happy that the replacement clutch is being fitted at a garage you're okay with. There may be those who aren't too happy with a Hellfrauds autocentre. I got my clutch fitted at a Mr Clutch - not always great but the guys at my local franchise were known to be great and indeed they were...
    123d MSport coupe from the company
    2007 S3 in sprint blue - gone!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Nothing wrong with Haldfords if the job is done properly. Make sure you get some sort of warranty on the work and it should be fine..Some might say however you should not change the clutch without doing the flywheel. depends on the mileage really.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    the dealer hasnt a leg to stand on, he sold you a car which obviously had a serious fault. Understandably he doesnt want to audi to fit a replacement clutch as they will rip him off. I'd try and find a local VAG specialist and get a price off them. Last thing you want is your clutch s****ing itself 5k down the road because halfords didnt fit it right!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    You'd honestly be better off getting him to agree to foot the bill,and then going somewhere proper like AMD or wherever you have locally,and getting a Sachs clutch and replacement DMF.
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    oem clutch = Cheese
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Mar 2011
    6
    What make of clutch should I get then , done by halfords or not, I mean like Lucas ? Sachs?, etc. The car has done 55000, will the flywheel need changing ? What is there life expectancy ? Thanks for you replys .
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    The Sachs is the best one for everyday use,on moderately modified and standard cars,as it feels much like the OEM one,but has much better torque limits.</p>
    You should change the flywheel at the same time,and yours has done really well to reach 55 000 without needing a new one.
    The Sachs in mine has coped with 24 000 remapped miles,and is currently coping with 440bhp/420lbs.
    Mar 2011
    6
    Quote Originally Posted by S3Alex View Post
    Thanks S3Alex
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Is the later OEM not a SACHs anyway? which is a better `version than the earlier LUK unit?
    Clutches are a real problem on S3s and mine was also changed by AUDI at 30K?
    The replacement felt slightly firmer than the failed unit so either it had improved clamping force or the LUK unit deteriorated prematurely.
    My DMF was inspected and found to be spot on so wasnt replaced. If the clutch has been slipping for a while however then the DMF will need changed and show signs of damage.
    Good luck getting it sorting, make sure the DMF is checked and everything is boxed up correctly. If you go the uprated route then stick a map on it!
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Whatever clutch you get make sure they know what way round to install it!
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    Quote Originally Posted by akash_sky1 View Post
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    Feb 2011
    Stafford
    I picked up my s3 2 weeks ago, 2007 with 27000 miles full audi history from a honda dealer. On the way home all was fine untill i accelerated on the motorway hard ish in 5th to get up to speed and the rev counter went form 3 to 4 thousand and did it every time in 6 th too.... Pulled off at next junction where I live and phoned them up. Basically told them I was having my car back and they agreed, whatever I wanted. Nipped into Stafford Audi where it has always been done and there was no record of any slipping. Anyway got back to The honda dealer and they were waiting and were very helpfull test drove, agreed and said car back or it will be fixed regardless of cost by Audi as they didn`t have the tooling for the job. So result in the end but poor show from the clutch........
