JMB RetrofitsChris Nott
Results 1 to 16 of 16
    pazaz's Avatar
    May 2004
    S.Wales
    316
    ECON & AUTO on together??
    When I put my climate control on the ECON light stays on too??
    If I hold the ECON button in the ECON light goes out. As soon as I release the button them ECON light comes back on.
    Is this right?
    cheers..
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Press auto, or a directional button
    Moved to the Darkside click below:
    pazaz's Avatar
    May 2004
    S.Wales
    316
    When I press AUTO Nothing happens.
    When I press a directional button the AUTO light goes off and ECON light stays on.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,377
    ECON light being illuminated means the AC is off.
    The fact it wont turn off indicates your AC is broken.
    TD5 Land Rover Defender build
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    yeah it should turn off when you put it in auto and if you push the econ button get it looked at
    ​She is back on the road yay!!
    27,099
    Check your fuses as this can happen if one blows.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    On the facelift climate, ECON has become A/C
    So does this still mean that AUTO illuminated is A/C on?
    27,099
    Auto will illuminate when none of the directional air buttons are on iirc.
    pazaz's Avatar
    May 2004
    S.Wales
    316
    Bugger!! Checked my fuses and they are all ok.
    Would this show up a a fault code if I took it to a garage to diagnose the part that needs replacing?
    pazaz's Avatar
    May 2004
    S.Wales
    316
    spoke to a automotive air con specialist today who confirmed it might need re-gassing (30) to sort this fault out.
    Any body know if this is sounds about right?
    pazaz's Avatar
    May 2004
    S.Wales
    316
    27,099
    30 isnt bad at all for a regas.
    Have you had car scanned as yet?
    Feb 2011
    Leeds
    149
    Would vcds cover heating and cooling faults? Mine has no fault codes, yet won't cool the car, so does this mean it needs re gas or a leak sorting if any?
    pazaz's Avatar
    May 2004
    S.Wales
    316
    If it does I will get it scanned first
    Is re gasin an easy process then?
    27,099
    Regas is easy with the right tools yes, depends on the fault tbh, but it can show some sensor/climate issue & as for does it need regassing, need to take to somewhere with kit & they can check if it needs doing.
    39
    Yeh it just needs the Gas re-filling its unlikely it will be anything else.
    30 is a great price, takes about an hour...
