Results 1 to 18 of 18
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    Coleraine, Coleraine, United Kingdom, United Kingdom
    515
    Question Stupid clock in my car. !??!!
    ok so I set car clock at the correct time (24hr style) then a few days later I got into my car and the time has changed completely.
    has happened a few times now and I have got to the stage were I don't even correct it anymore as no doubt it will be wrong the next time I get into my car.
    any ideas?
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    [ BUMP ]
    anyone have any idea?
    Khufu's Avatar
    West coast of Scotland
    5,693
    im guessing there could be a bad connection between the cluster and the multiplug so its loosing the permanent 12v supply.
    27,121
    Yeah I'd go with power related, either battery is iffy or you have wiring/cluster problems.
    I have a used red dis cluster for a tdi available if any use, could stick that in car overnight see if that also has issues then you'd know if as car or cluster side at fault.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Does the trip mileage and mpg etc reset as well as the clock ?
    Khufu's Avatar
    5,693
    Good point :-)
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Ah..you can see the way i am thinking ...power cut or clock fault
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    Or, one of those radio time controlled clusters? Depending on where you are and presence of pirate radio stations etc and lazy DJ's/MC's who don't set their station RDS clocks ..
    Khufu's Avatar
    5,693
    Ive seen the part number in ETKA for a radio controlled clock module but dont know anything about it.
    27,121
    AFAIK the radio clock module actually gets its signal from a european transmitted signal that I dont believe is via the radio stations rds etc system as such & afaik it wasnt available in UK, buttt, I have it on my list to do to test anyway, so watch this space.
    It requires a receiver on the boot area iirc.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    My wrist watch gets its signal from several places in the UK. its the size of std medium size watch. Why would Audi need a receiver in the boot :-). the signal for the watch is actually world wide and covers all time zones. so it can work out if its receiving UK time or Euro time. This way it is correct anywhere in the world or can show the time anywhere in the world while in the UK. Its uncanny the way it beeps the hour to the second with the BBC time signal.... good old 21st century :-) Audi will get there one day !!
    I doubt the DIS gets RDS info as the RNSE only repeats the DIS time.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yep it's nothing to do with RDS it's transmitted from an atomic clock. I always wondered why it's not an option in the UK though.
    8P2 S3
    27,121
    Quote Originally Posted by paddy View Post
    Thats where its stuck mate, on the rear bumper area, guess thats where its most open to the air & wont get covered in crap from the road, who knows.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Yea..wasnt meaning to be facetious.....what imeant was if you can fit the whole thing inside a watch then you would think it would be in the DIS module rather than a far away as possable from it in the boot:-) ....or maybe in the auto lights/wiper sensor on he screen.
    27,121
    & mate, didnt read it that way either, just more information for you all.
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    515
    nope just the clock Paddy. what you thinkin?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Thinking if its a power cut to the dIS then all the readings would reset. not just the clock. so it looks like a dodgy connection maybe in the dIS rather than too the DIS. NHN will be along soon i expect and he is the electrical wizard :-)
    If you have an RNSE the time on that is set via the DIS clock as well so presumably that is going back to zero as well ??? not sure if other head units use the DIS clock, again one for NHN :-)
    Nov 2010
    Essex
    9
    With regards to the atomic clocks, I have 2 alarm clocks set via radio waves and every now and then they show the wrong time (several hours wrong rather than a few minutes), but they seem to correct themselves again within 24 hours, so don't rely on them always being correct.
    It always seems to happen during the night so not sure what causes the interference.
