Volks AutosSky Insurance
    brough74's Avatar
    Oct 2010
    423
    S3 fog light grill removal
    Hi i have a 2008 S3 8P2 and i want to remove the fog light surrounds/grill, and then the solid backing plates to allow a hole to be cut in it for an air intake.
    Do they pull off or unscrew ?
    S3 gone but not forgotten, now on a Golf R
    42
    pull off. what size ducting are you using?
    brough74's Avatar
    Oct 2010
    423
    Not sure yet i will see what i can get in
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,807
    Pull off fella just be careful not to brake any clips.
    Dark Vader Half sibling - MyThread
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    Pull off, if I remember its eaiser if you start on the outside edge but as said mind the clips, they snap off easily
    27,087
    Pull of in the fog corner 1st towards the front of the car, then slowly prise the edges out, they can get stuck tight in there & break the edging, so patients needed.
