Monster MotorsportBadger5
Thread: SDS Woes
    Dec 2010
    68
    SDS Woes
    I think I've finally got the RNS-E figured out.
    Made a start on the SDS today but can't seem to get it to do anything other than control the phone - which is a bit dodgy in it's operation.
    It won't control the radio, CD or nav. Have I got some sort of limited functionality SDS?
    If that's the case is it possible to upgrade to full functionality and is it a big job?
    I assume the car currently has an 07 DVD in it - not sure as the DVD seems to be in anti theft mode at the moment.
    Jon
    Khufu's Avatar
    West coast of Scotland
    5,693
    Most of the RNS-E's need the SDS hack to work, have you used the patched firmware?
    The mic also need to be wired in correctly. There is a lot of info to be found on Audi Forum
    May 2010
    London
    334
    As Khufu said you need to wire the mic in. I have the SDS on my RNS-E (previous owner enabled it) but i still had to fit the wire, wasn't too hard, hardest bit was probably getting the A piller trim off.
    Dec 2010
    68
    Thanks, I strongly suspect that the unit is still on the 07 firmware. The disc won't eject and I think the coding is set to antitheft mode. I'm planning on getting a 2011 disc for it so that should update the firmware (along with coding it so the disc will eject - obviously!)
    I'll pay somebody who knows what they're doing to sort the rest out!
    27,089
    & yes I can add this to the work mate
    Dec 2010
    68
