EM TuningMonster Motorsport
Results 1 to 17 of 17
    May 2009
    52
    Car cutting out when going over bumps - sportback 1.9tdi
    As above-
    My 05 sportback loses power/cuts out (has stalled twice) occasionally- the common denominator seems to be when I go over bumps/pothole infused roads. Doesn't happen every time, but a speedbump/bump/pothole is always the catalyst for it!
    Any thoughts? Have scanned via vcds but no fault codes relating to the prob (one for a electric window, one for aircon I already knew about).
    Any thoughts??
    May 2009
    52
    Bumpage!
    Fossie
    Rhubarb Triangle
    3,969
    I see you have bumped the page mate - I would suggest that the lack of replies are due to nobody having had the same problem
    I have certainly not heard of it !
    Only thing I can think of is a loose connection somewhere, possibly in the injector loom or the fuel pump, causing an intermittent fault.
    Hope you get it sorted
    May 2009
    52
    Cheers Mike - No joy checking connections - its still the same.
    I scanned with VCDS - apart from probs with aircon / lights i knew about - its throwing up a 01314 code regarding the engine control module - might this be affecting it?
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CC HW: 028 101 183 2
    Component: R4 1,9L EDC 0000SG 6231
    Revision: 12345678 Serial number: AUX7Z0D9FND0BK
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 N
    Component: ASR FRONT MK70 0103
    Coding: 0017025
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 105846 Serial number: 8P0820043D
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 198
    Reset counter: 119
    Mileage: 226825 km
    Time Indication: 0
    Date: 2010.09.18
    Time: 21:59:02
    Freeze Frame:
    Temperature: 4.5C
    Voltage: 12.10 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001126281
    Coding: 01884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
    010 - Open or Short to Plus - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 00362000RVWF
    Coding: 0033622
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksulenmodul 012 0030
    Coding: 0000002
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 900 F HW: 8P0 920 900 F
    Component: KOMBIINSTR. VDO H72 0210
    Revision: D03 Serial number: 1249DD03013973
    Coding: 0004448
    Shop #: WSC 00411 210 03906
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001049270233
    Coding: 3D3F0B42072103
    2 Faults Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 119
    Mileage: 232699 km
    Time Indication: 0
    Date: 2011.02.11
    Time: 17:20:30
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D03 Serial number: AUX7Z0D9FND0BK
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000016
    1 Fault Found:
    00912 - Window Regulator Switch; Front Left (E40)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    1 Fault Found:
    Freeze Frame:
    Mileage: 3440 km
    Temperature: 20.0C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 E
    Component: KSG H04 0050
    Coding: 188000186D088505489F016000
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH02 0160
    Revision: 00001 Serial number: 10000001189590
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000016
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3D1535597
    Coding: 0001001
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    Fossie
    Rhubarb Triangle
    3,969
    This might help :- 01314 - Ross-Tech Wiki
    May 2009
    52
    Cheers Mike
    So there seems to be an issue with the ECU judging by the Ross-Tech site, connection problem (either internal or external).
    The other code 00188 appears to be related to the ignition - if I'm right, if this is dodgy it'll kill the power, yes?
    I'll get my brother in law to have a look at the car at the weekend - I've heard you need a heatgun to remove the ECU shroud!
    Failing that, can I check terminal 50 - is that a relay switch?
    Fossie
    Rhubarb Triangle
    3,969
    Not sure about terminal 50 mate - sorry
    Just noticed that at address #44 mileage is shown as 3440km
    Has something been replaced to your knowledge ?
    May 2009
    52
    I replaced the battery around the start of December - would this have caused it?
    I also slid into a kerb around this time, knocked the wheel a bit but no damage - would this have affected the ABS signal problem
    May 2009
    52
    Cleared the DTCs - haven't popped up since yesterday anyways.
    Totally stuck. The car only judders and stalls if I have my foot on the throttle over the bumps, if I coast over them using the clutch in then it continues over them as it normally would.
    Does this narrow it down any?
    Cheers for the help guys - at a total loss here!
    May 2009
    52
    Right, went a week with the car as normal. Quit
    Stalling just as my mechanic took a look at it - sods law and couldn't recreate it!
    He checked over all connections and everything seemed ok.
    Until today, stalled badly going over bumps and on the dual carraigeway. At one point it stalled pretty badly, with the glowplug light flickering in the dash and a clicking sound coming from behind/under the steering wheel. Then, within a few seconds, it returned to normality again!
    Any thoughts on this? Is there anything I could measure with live data via vcds? Is it a relay (have heard there are some below the dash?)
    Apr 2011
    197
    50 terminal is the starter cranking feed but shares the same multi plug connection under the engine bay fuses and relay plate as the voltage supply relay for the engine ecu, so you have a small indication your fault may lie there.
    You need to establish if the ecu is losing its 30,31 and 15 inputs when it cuts out
    You can do this by back probing the ecu and connection a voltmeter or checking the voltage supply with vcds
    In both cases you will need to drive around with either connected to monitor but I would simply check all connections on this circuit for loose pins or corrosion
    Also don't ignore the can crashing again you can check this in mvb 125 in address 19 amongst others as there's a drop between abs and engine ecu.
    The benefit of address 19 shows you all the drive train status with 1 = working and 0= not working but if it flickers between 1 and 0 then you have a contact problem either internally or externally on the highlighted control unit (in your case engine ecu)
    Good luck and yes you will need to remove the tamper bolts by applying heat then use mole grips to remove them but not to much heat as your heating the ecu casing (they are a bugger)
    May 2009
    52
    Cheers A8 tech - will get on it.
    Update - the car had a bit of bother starting and the glowplug light was flickering. Scanned and it came up with a fault:
    16705 Engine Speed Sensor G28 : Implausible Signal.
    According to Ross-Tech this means the sensor is kaput/faulty or the wiring attached to it!
    Does this sound like i might have found the solution to this annoying problem??? Hope so!!!
    On the offchance, does anyone have the part no for this bad boy (G28 sensor)??
    Thanks all for the assistance - hopefully getting near the end!
    Fossie
    Rhubarb Triangle
    3,969
    What's your engine code mate ?
    May 2009
    52
    BKC.
    Thanks a million. Sound like a cure?
    Fossie
    Rhubarb Triangle
    3,969
    Could be the problem but substitution is the only real way of checking I think.
    If somebody could confirm that another name (ETKA name) for G28 speed sensor is 'Impulse sensor crankshaft' then the part number is :-
    036 906 433 B.
    May 2009
    52
    Update on this:
    Mike, cheers - that was indeed the part number, got the G28. After getting it, and with the car nigh on impossible to start, it threw a 16706 No Signal code. This was accompanied by serious power loss and revving.
    My brother in law went to fit it this weekend, thought it would be a fifteen minute job. Boy, were we wrong!
    It was located next to the flywheel, so a lot of stripping out had to be done before getting near to it. Even then, the sensor, approximately 2" in depth, was in some sort of hole that an allen key had to be inserted, blind, into. Even then the allen key had to be worked at an angle due to the shape of sensor but could get no purchase on it!! sensor here: http://images.esellerpro.com/2366/I/...036906433E.JPG
    So, to get at it - the gearbox had to come out. Long story short, it's in and the car is driving dandy again - actually better than i can ever remember. Cold starts are really smooth (the car used to jolt when starting) so am happy!
    Thanks to everyone for the help!
    Fossie
    Rhubarb Triangle
    3,969
    Thanks for the update mate - glad you got it sorted !
