AH FabricationsChris Nott
Results 1 to 10 of 10
    Jan 2011
    36
    DSG gearbox, how to change between gears?
    Hi guys,
    Im after ordering a new A3 1.4t dsg, my question is what do you have to do to move between the different drive options? i.e. do you need to press down on the stick and then slide, or is there a button im not seeing?
    i know it prob seems like a stupid Q, but im a wheelchair user and have reduced hand function so may need to adapt the gear lever. Im famaliar with old style lever as have something similar on my golf gt and works fine for me, any info would be great.
    tks
    May 2010
    Oslo, Norway
    142
    Hello!
    You push a button on the stick and slide up and down.. as far as i know
    2010 SB TDI - Accuair E-level - Air Lift Slam front and rear - Bentley CGT 9 spokes - Votex hatch spoiler - S3 front and rear - RNS-E mk2
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    Theres a button on the side of the stick. which will allow you to slide it up and down.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    Theres the button on the side of the stick as mentioned above or you can use the paddles on the steering wheel. But to engage neutral etc you would have to use the gear stick.
    My wife recently had a test drive in a new Polo 1.4t with a DSG gearbox and the button was on the side of the srick closest to the centre console rather than on the side as my current S-tronic (DSG). I think this is similar to those on the S3.
    She did in fact find it a bit more difficult to use that the side button which is just where you place your thumb on the stick and the Polo didn't have steering wheel paddles either.
    Dave R (h5djr)
    Jan 2011
    36
    tks all 4 the info, does anyone have a pic of where the button is? just cant find any closeup pics of the new style gear lever showing the button.
    tks again
    2011 a3 1.4t dsg (ordered)
    2007 golf gt 1.4tsi
    May 2010
    Oslo, Norway
    142
    a friend of mine has this knob in his 1.4t my10
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    i see this is a 2011, think the button is now at the very front on the stick! From what i remember driving one a few months back, you can go form R - N - D - S just be holding the on the break pedal and pushing/pulling the gear stick back/forth! The button only needs to be used to get it into P and out of P
    Moved to the Darkside click below:
    Dec 2004
    133
    The button (front, side or wherever) is used to ulock the lever from the P position. Move the lever backwards to the D position and you are in auto mode. Changing up/down in D can be accomplished by utilising the paddle shifters, but if the lever is left in D after a period of time the system reverts back to auto.
    With the lever in the D position you can move it to the left and you will be in manual mode with M showing in the DIS. You can now change gear using the paddles or pushing the lever forwards to go "up" the gearbox or pull back to go "down" the gearbox. In M mode the electronics will take over if you "forget" to change gear.
    Moving the lever fully back to the S position puts the gearbox into Sport mode where the gears are held longer and much further up the rev range. This can also be used for launch control but that is another story.
    A4 Avant 2.0TDI 143 Black Edition, Daytona, Alcantara, Heated Seats, Tech Pack, Advance Parking, Light Pack + full LED upgrade, Power Tailgate, S Line Sports Suspension
    Jan 2011
    36
    tks for clearing this up, should be ok w/o modifying if it's just a button on top of stick.
    2007 golf gt 1.4tsi
