Chris NottEM Tuning
    heyadamhey's Avatar
    May 2009
    Joburg, South Africa
    126
    Aircon fan won't turn off
    Hi guys,
    I had a similar problem about a year ago - my radiator fan wouldn't turn off, and it turned out the sensor inside the fan was buggered. Replacing the fan solved the problem.
    Now the other fan stays on (smaller of the two behind the radiator).
    Can anyone confirm whether the same solution applies to the aircon fan? Is the sensor inside the fan itself?
    Adam
    Akoya TDI 140, 18" S4 Rims, VCDS, H&R
    Getting Hybrid treatment
    27,099
    Just grab a whole used fan unit of the bay & swap it out to test.
    heyadamhey's Avatar
    May 2009
    126
    That's what I had in mind, just wondered if anyone had experience with the same issue
