Chris NottJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
Like Tree1Likes
Thread: Jacking Up An A3
  1. #41
    Fossie
    Rhubarb Triangle
    3,969
    Yes they do mate in atp, but when you check the model column it says S3.
    Update 848.
    Just as a matter of interest Nige, is the S3 chassis any different (in general terms) from the A3 ?
  3. #42
    Sep 2009
    Trotters, Peckham
    539
    You guys look like ya need some help
    Fourtitude.com - DIY - Jack Pads
  4. #43
    Harrelson's Avatar
    May 2010
    173
    Quote Originally Posted by Smoothie View Post
    Ok as the title suggests, the jacking points are clearly marked on the sills! But jacking on the pinch weld with a trolly jack can damage it as far as i can see! The little emergency jack is specially adapted for the pinch weld but i wouldn't be too keen on using it TBH
    So is there a jack pad i can buy for the trolly jack to save damage to that area? Or is the old fashioned block of wood the only option?
    Thanks in advance
    You can jack up an A3 with a flat trolley jack. Had it done on my A3 on both front and rear by an Audi Tech
    2009 A3 1.6 TDI Sport Phantom Black, iPod and RNSe
  5. #44
    Fossie
    Rhubarb Triangle
    3,969
    Will let you know when I've got them tomorrow.
    BTW both come up on A3 on my ETKA !! (update 847)
    Got the bits today - needless to say typical VAG quality and fit perfectly !
  6. #45
    27,105
    Pics.
  7. #46
    Fossie
    Rhubarb Triangle
    3,969
    Pics.
    Tomorrow mate - providing it stops raining !
  8. #47
    Fossie
    Rhubarb Triangle
    3,969
    As promised - here are the pics of the jacking pad install :-
    Pic 1 - The two parts
    Pic 2 - The removed cover plate
    Pic 3 - Install position
    Pic 4 - Installing the pads
    Pic 5 - Finished install
    Pic 6 - Being used
    Two things to bear in mind chaps.
    Once it's in it doesn't come out !!! - now I know why that website sells them in fours !!
    Finally, you can't replace the plastic cover plate 'cos the fixing hole is already in use !!!
    Total cost 5.44 and install time of approx 30 mins of which the first 15 were figuring out how to get the cover plate off. You just lever it with a big screwdriver !!
    Sorry about the pics guys but I'm not very good under a car - it's the arthritis you know !
    Lima likes this.
  9. #48
    brettp's Avatar
    Jun 2009
    99
    Sorry guys on this one, I sent Bero a message on DW and asked him if he was ok for me to post his email, he said that he wanted to post himself so that he could keep track of items and orders.
    If people are still interested I will get him to come over (again) Ive now subscribed to this to not miss anymore updates
  10. #49
    Feb 2011
    535
    Quote Originally Posted by brettp View Post
    To be honest mate, I think the above 'official' solution would be more ideal.
    I know it will be for me anyway - to have permanent trolley jack pads at the ready :-)
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
  11. #50
    brettp's Avatar
    Jun 2009
    99
    Yeah that's no problem, I think that I am going to look at these also, just wanted to apologise also for not noticing the thread.
  12. #51
    27,105
    Thanks Mike, will be checking them out soon.
  13. #52
    Fossie
    Rhubarb Triangle
    3,969
    Ok mate - another thing - I didn't check the rears but I don't think there's a cover plate at the back. There is on the near side though, my pics are the drivers side.
    Just looked at the pics again - **** I forgot to rotate the last one !!!lol
  14. #53
    27,105
    Yeah I do actually recall some holes like your pics show, whether I'm confusing with the rear lower arm spring holes, who knows lol.
  15. #54
    brough74's Avatar
    Oct 2010
    423
    I bought a rubber pad off ebay and then cut a slot in it with a grinder and chisel so it will still lift the car but not flatten the lip, or it could be used for the locations mentioned
    S3 gone but not forgotten, now on a Golf R
  16. #55
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    Ordered my Audi jack points today 
  17. #56
    dantdi's Avatar
    Feb 2008
    kent
    511
    Cheers for the part numbers Mike Foster.
    Got set jack pads today.
  18. #57
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by dantdi View Post
    You're welcome - glad to be of assistance
  19. #58
  20. #59
    Agric04's Avatar
    Feb 2011
    198
    I've just fitted the genuine Audi jacking points to my 2001 S3 8L, easy enough to fit, I used a bit of soapy solution and the piston out of an old brake caliper to help press them into place. I paid 18.12 in total for all 4 mounts from Boston Audi. Below are the pictures of my install:
    Could someone please reassure me that I am jacking the car up in the correct place. I have fitted all my mounting points and although the rear points seem nice and strong the front points don't inspire me with confidence. The front hole where these fit into looks to buckle in when you put the full weight of the car on them. I have no fancy plastic cover underneath my 8L unlike the 8P's so it's easy to see if the under pan is flexing.
    Current:
    2013 Audi A5 Coupe Black Edition 2.0 tdi 177 manual with t
    echnology pack, interior lighting, cruise control, heated seats.
    Past:
    2006 Mk5 VW Golf GT 2.0 tdi 170
    2001 8L Audi S3 1.8T
    1998 8L Audi A3 1.8T
    1996 Mk3 VW Golf Gti 2.0 8v
    1994 Mk3 VW Golf Gti 2.0 8v
    1986 Mk2 VW Golf driver 1.6
    1987 Vauxhaull Nova 1.0
  21. #60
    Fossie
    Rhubarb Triangle
    3,969
    Better pics than mine mate ! Can't reassure you because I don't know about the 8L chassis.
    However, if the pads fitted tightly to start with but you can now twist them in the sockets then it would seem that they are 'made to fit' the holes you have used. As you have bungs in other holes then I would assume that if these were not the right holes, then they would have had bungs in as well !
  22. #61
    dantdi's Avatar
    Feb 2008
    kent
    511
  23. #62
    Oct 2010
    97
    Is this right what it says in uk-mviks?
    OFFICIAL VW word: Just went to see a friend at the dealership. He showed me a memo regarding these pads. As the update says, they are to be used when lifting the entire vehicle using a floor lift. When used all together, they distribute the weight of the vehicle and don't cause harm. But if you use on at a time, you are putting too much weight on one point and will bend the floor pan. Think about it this way, one pad would be attempting to lift at least half the car.The two jack pads are to be used when lifting the vehicle using a floor jack. Then place a jack stand on the frame rail.
  24. #63
    Sep 2010
    Telford/Shropshire
    366
    lads dont meant to be rude .but all i see in here in this pic is a simple'' ice hockey puck'' with a big efin chunk being cut out of it.
    so you might as well manufacture theese for ur self.just buy a hockey puck and get some proper tools for the cutting part as its vulcanized ruber (quite strong)
    Proud owner of a:
    2.0T FSI quattro A4 S-line (saloon)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
  25. #64
    Feb 2011
    535
    Quote Originally Posted by owenjt View Post
    This has got me thinking now....
    Can anyone on here confirm that they have jacked up their A3s with the pads without any bother to the floorpan? I bought some the other week but yet to try them out.
  26. #65
    27,105
    TBH it stands to reason tbh, if that areas not reinforced then it can cause deformity, I'm steering clear.
  27. #66
    Feb 2011
    535
    So if you wanted to jack up the front of your A3 with a trolley jack and put it on stands, how would you go about it?
  28. #67
    1inchpunch's Avatar
    Apr 2011
    Glasgow
    449
    I jacked my car up by putting the jack just past the seam. I use a rubber pad that is actually an old rubber CD wallet that is about 3cm thick. Done one side, slipped an axle stand in then did the other side. The trouble I had was that the road outside my garage appears to be soft as pudding as the axle stands had dug into the road when I went to remove them 2 hours later.
    the crisis mobile BMW Z4C 3.0
    It's quick and it sounds bloody good.
  29. #68
    Feb 2011
    535
    Quote Originally Posted by 1inchpunch View Post
    What jack did you use Paul, and when you say just past the seam, where do you mean exactly in relation to the jacking notch recommended for the standard scissor jack?
  30. #69
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Part nos :-
    8N0 803 855 mounting for service lift �3.54
    8N0 804 583 mounting for service lift �1.80
    Two pieces of solid rubber, one forces firmly inside the other to provide stable fixing for trolley jack.
    As per this photo Volkswagen Golf V 2.0T > Exterior > Body > Jack Pad > ES#2583 OEM Jack Pad Kit - MK4JPPK
    Obviously the price quoted in the picture is for 4 sets but still cheaper at Audi !
    Sorry to bring this thread back to life Mike,
    Going to order these as like many others, I damaged the vertical jack points using a trolley jack. Lucky I got side skirts so it does not show.
    Question is, when I give my dealer the part numbers you kindly supplied, do I order two of each, one for drivers and one for passenger?
    Also would these be the same for the rear?
    Until they arrive, if I remove the trim as you showed, do you or anyone else thing I would be ok using a bit of wood on that point just as a temporary measure.
    Many thans
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  31. #70
    Fossie
    Rhubarb Triangle
    3,969
    Forgotten about this thread !!
    Yes, you need two of each. As you will see from the photos one part actually goes inside the other and then into the jacking point.
    As far as I'm aware the rears are the same although I haven't got them.
    Once the cover is removed you can use that jacking point with a block of wood or something provided it seats properly on the jacking point.
    One thing to bear in mind is that you should really jack up both sides at the same time (presumably using two jacks) to ensure that you don't twist the chassis too much.
    Good luck.
  32. #71
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Many thanks Mike,
    Thanks for the quick reply.
  33. #72
    Aug 2011
    277
    I solved this problem years ago and used on many cars. First a hard block of rubber placed on the jack cradle. ( several layers of rubber mat sections gaffer taped together works for a while ). Then using a section of old rubber pipe ( the cold/hot flexible pipes used for washing machines is ideal ) cut lengthways and slid over the seam. What is mega sad I have made a set of 4 using red washing machine pipe and they are permanently in place at the jacking points.
  34. #73
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    2x4 with a groove cut in it for the jacking point. job done
    For Sale -
    A3 rear wiper motor and arm
    A3 air vents
    56plate A3 S-Line full speaker system including amp
  35. #74
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    295
    any idea if these will fit an 8L s3?
  36. #75
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Far simpler and cheaper way is, use a small block of wood in conjunction with flat topped/padded jack.
    Works for me every time on the GTi or A3.
  37. #76
    Synchromesh's Avatar
    Will Race For Cookies
    Jun 2009
    Belgium
    99
    I just use the points described in the manual (I don't use the standard jack though, that thing is scary)... I've done this many times and my sills are still perfect.
    On a related note, can someone point out where I should put the jack stands at the back of an a3?
    Phantomschwarz Audi A3 2.0 TFSI quattro S-Line | Bilstein PSS B14 | Oem 8x18 ET43 5-Spoke | Facelift taillights | RNS-E MKII | My Thread
