Monster MotorsportVolks Autos
Results 1 to 14 of 14
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    standard alloy centre cap removel?
    http://i1202.photobucket.com/albums/bb371/s3kel/s3.jpg
    hi to remove centre cap on alloy .do you remove it with an allen key...(hex) looked in boot of car nothing there...
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    na that wont get it out
    there will be a little cut out with a bit of wire in it that will hook it out mate
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    hi jungleman hows things,, seen the little hole... but how do i get in there,,,
    267
    In the foam under your boot lining, on the right hand sight behind the rear seat there should be a metal loop with a little hook on the end - it should be recessed into its own cutout in the foam. You just use the hook to put in the hole on the centre cap and pull it off.
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    yea not too bad, car is still sick, but taking it in soon to get it all sorted
    in the boot there will be a bit of wire, somewhere near the back of the polystyrene, get that stuck in the hole and bobs you uncle
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    thanks one spoke will look tomorrow in the light thanks,,
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    thanks,,shame jungleman about your car you not using amd to sort it..
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    na the car is still under warranty so will be making sure Audi foot the bill! im pretty sure its just coilpacks anyway so nothing to major
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    Audi Centre Cap Removal Tool on eBay (end time 01-Apr-11 19:23:38 BST)
    hi jungleman is this the one? just incase its missing ,will have to pop in to hadwins in kendal tomorrow...
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    thats the one... unless youve got a wire coat hanger laying around as that will do the job lol
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    thanks mate,, also inside the petrol flap its says 39 psi front ,,30 psi back for tyre pressure at bottom on top its more do you know what pressure i really need on startard alloys,,put 35psi in all 4 today still does not seen right...
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    haha that confuses the hell out of me! i run 38 all round and that makes it pretty firm! dunno if thats right tho lol
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    thanks mate sounds good to me,,
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    no worries mate
