Sky InsuranceBadger5
    Feb 2011
    41
    coolant leaking 2.0 bkd tdi.. Dripping from under
    My 2004 2.0 gt tdi just started leaking slightly only when the engine is running. I can drive for about 20 mins before the light comeson and i have to top up. Its leaking from the undertray and looks like it coming from the radiator.
    Gonna have a look tomorrow properly under, i hope its a pipe and not the rad.
    Anyone have any problems like this?
    Fossie
    Rhubarb Triangle
    3,969
    Most people to be honest !!
    Sounds like the radiator which is a common problem both on the A3 and Mk V Golf.
    Not too bad to replace moneywise and much better than losing coolant the other way - via a porous cylinder head !!
    Might be a pipe but look at the bottom passenger side of the rad for leaks.
    Feb 2011
    41
    Yeah it seems to be coming from the passenger side on the rad.
    Oh well. If it is the rad Shall i go oem or eurocarparts do you think? how much am i looking at for the part oem
    thanks
    Fossie
    Rhubarb Triangle
    3,969
    OEM part is 225 - part no. 1K0 121 251 N
    Eurocarparts or similar should be nearer half that I would think and will be just as good.
    Feb 2011
    41
    thanks mike!
    Fossie
    Rhubarb Triangle
    3,969
