Volks AutosBadger5
Results 1 to 16 of 16
    Nov 2004
    66
    Offset on 18\" rims for New A3
    Hi guys,
    Wondering if I can get some factual info from the people that know!
    Mu question is simply, what offset rims are people running on their own cars if they are 18" or 19" as I'm getting conflicting info from the stealer & so called wheel experts (who just happen to have a set in a 35mm offset! [img]/ubbthreads/images/graemlins/burningmad.gif[/img])
    I ask because I'm replacing my 17" sport alloys with a set of the 18" S8 Avus alloy's with a 48mmET which I hope&think will be fine.
    Thanks in advance
    Cupramax's Avatar
    Uber pimp meister
    UK
    455
    Re: Offset on 18
    I think you'll find the S8 wheels will stick out too much and rub your arches. I'm pretty sure the latest A3 is ET42.
    Re: Offset on 18
    According to the details of the wheels on the ETKA Parts Catalogue the spec for alloy wheels on the new A3 is:
    17" - 7.5Jx17H2 ET52 5/112
    18" - 7.5Jx18H2 ET54 5/112
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    Re: Offset on 18
    yep ET54 on my 18''
    here is a pic
    Nov 2004
    66
    Re: Offset on 18
    Dave & StephV6 Thanx a lot for prompt response.
    So therefore a 6mm difference in the offset shouldn't be a big prob then?
    And am I right in thinking that the 6mm difference will relate to the wheel sitting 6mm further in (i.e closer to suspension / hub) than if the offset was the correct 54mm.
    Have a loook at this illustration & help my struggling little head!
    http://www.discountedwheelwarehouse....ment_Guide.cfm
    Once again, I knew you guys would know!
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: Offset on 18
    No it's the other way round. A wheel with a 54mm offset will sit closer to the hub than a wheel with a 48mm offset.
    J.
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    Re: Offset on 18
    marriedblonde's right
    so et48 would mean 6mm outwards
    but you should have plenty of space look mine again with standard et 54
    Nov 2004
    66
    Re: Offset on 18
    Thanx again Steph, [img]/ubbthreads/images/graemlins/beerchug.gif[/img] just had a heart in mouth moment there thinking I had got it all wrong!
    Dec 2004
    Sunny South Coast
    4,368
    Re: Offset on 18
    I put ET30mm BBS rims on my R32 instead of 35mm and then stuck 5mm spacers on the back and didn't have any problems.
    I would have thought the 48mm ffset wouldn't cause too much of a heart ache. You'll almost definately be fine with the rear arches, it'll be the fronts that catch if at all. But looking at Steph's pic above it looks like 6mm won't be an issue.
    J.
    Nov 2004
    66
    Re: Offset on 18
    Marriedblonde, thanx.
    But I'm confused with the offset issue a bit, some were saying the 48mm would stick out further than the 54mm recommended.
    But I thought, and your last post confirmed this (I think) that a 48mm offset could be made into a 54mm offset (like U with a 30ET & a 5 mm spacer) with a 5/6mm spacer?
    Dec 2004
    Sunny South Coast
    4,368
    Re: Offset on 18
    No sorry, what I was trying to explain was that although my golf should ride on 35mm offset wheels I fitted BBS CH rims that only come in a 30mm offset which pushed them further out towards the arch I was still able to fit 5mm spacers on the back. Effectively making them a 25mm offset wheel without any problems.
    So basically the lower the offset the further out away from the hub the wheel will sit.
    J.
    Feb 2004
    Clearfield, PA
    892
    Re: Offset on 18
    the mkIV golf and the old Audi a3 have the same offset of around 35
    whereas the new 8P Audi a3 has an offset of 45... checked this many times when getting mine...
    bravepilot's Avatar
    Oct 2004
    South Hams, Devon, England
    624
    Re: Offset on 18
    [ QUOTE ]
    [/ QUOTE ]
    SteveV6, I like your parking... so close to the curb... You pass your driving test, well done! [img]/ubbthreads/images/graemlins/lol.gif[/img]
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    Re: Offset on 18
    [ QUOTE ]
    BravePilot said:
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    thanks! [img]/ubbthreads/images/graemlins/grin.gif[/img]
    but I dont do that anymore
    fu(kep my alloys a couple of time before but now that I've got the new wheels I dont park that close!
    Mar 2003
    UK
    426
    Re: Offset on 18
    I was going to ask how you got out of that parking space without kerbing the alloys!
    I agree with Richy. I have only seen ET45 mentioned everywhere in relation to the new A3. For the old A3 it always says ET35.
    The amount wheels stick out - it also depends on the width of the wheel doesn't it?
    Also, can you fit 235 width tyres on a 7.5J wheel? Any reasons not to? Would it not make the tyres wider (natch) and protect the rims better as the tyres would bulge out more?
    Another q: What about HW (is that right) tyres? Tyres with stronger sidewalls? The only reason I'd rather not get 18/19s wheels (love the MTM Bimotos, but they don't come in 18s) is the very low profile tyres you need to use. Would hard wall tyres reduce the risk of damage from potholes etc?
    Dec 2004
    Chester
    247
    Re: Offset on 18
    The "ET" of a wheel is the distance from the wheel centre line to it's mounting flange, as with everything else it gets a bit confusing as we measure wheels in inches and offsets in mm, diameters of tyres in inches, widths in mm.
    The "ET" does take a bit of sketching out to see if you are going the right way. It also depends on the width as well, a 17 x 8 et35 will stick out 0.5 inch more than a 17 x 7 et35
    Or, have a look here http://www.turner-auto-design.com/wheeltech.htm
