JMB RetrofitsEM Tuning
Results 1 to 7 of 7
    Feb 2011
    535
    RNS-E compatible with iPhone 4?
    I tried out the built-in iPod connection in the glovebox today only to find that nothing happens - no charge and no recognition from the RNS-E.
    Is my iPhone 4 compatible?
    27,073
    Probably because the ipod interface needs an adapter for iphone 4, how old is the interface as if before iphone 4, then probably cause pins were moved about again by apple arrgghhhh
    Feb 2011
    535
    Ah I see what you mean.
    So I need to look into swapping out the actual ipod connection for a new one?
    27,073
    Well you could just find an adapter cable to plug into the ipod interface that converts the pins or try repinning yourself, bit of a ball breaker, alternatively if you want full iphone etc integration then upgrade system to mk2 rns with ami of which I do, not cheap but nice setup.
    Feb 2011
    535
    Would it be a cable that runs from the back of the RNS-E to the glovebox that I'm looking for?
    27,073
    No, was thinking a cable that plugs into the ipod adapter then into the iphone 4, think I've seen some somewhere.
    Feb 2011
    535
    Ok that seems easy enough and means I dont have to reach right in everytime I need my phone.
