Chris NottEM Tuning
Results 1 to 11 of 11
    nelson19uk's Avatar
    There's no poke without smoke!
    Feb 2011
    Aberdeen
    152
    Window function stopped working from my remote.
    As above says. Stopped working a couple of weeks ago. I noticed that the windows auto close function from the drivers side controls sometimes doesn't woork either.
    Thanks in Advance
    ________________________________________
    Vroom Vroom!
    Stage 2 Custom code Remap, BSH Trueseal CAI, Milltek resonated decat Turbo back, Platinum grey wheels.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,049
    Prob the `one touch` function needs reset. If this goes off then the fob closure does the same.
    Drop the drivers window with the switch and hold it for 10secs after the window is all the way down. The repeat for the `up`position.
    Then repeat above for the passenger side.
    Should see you reet.
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    nelson19uk's Avatar
    Feb 2011
    Aberdeen
    152
    I'll give that a bash tonight. Thanks for the tip mate. Was woorying it was something major.
    Vroom Vroom!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,049
    Its a common thing mate.
    iirc its a software update for the Window Modules.
    Its a FOC job at the dealers.
    My window module ended up ****ting itself in the end so the software was sorted at the same time as a new module.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    nelson19uk's Avatar
    Feb 2011
    Aberdeen
    152
    Dunno about the stealers like. The one in Aberdeen charges for everything. Bunch of Cants
    Mine is out of warranty too so couldn't even try that one.
    Can you do the sw update with VCDS?
    Vroom Vroom!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,049
    Quote Originally Posted by nelson19uk View Post
    Not sure mate, NHN will know whether VCDS can update the software, I would guess not.
    If it was a recall then the dealer should do it FOC. Failing that, you will just have to manually set them periodically.
    good luck
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    27,126
    Just reset them as Paul advises, fixes problem in 30 seconds, going to dealers etc would be a pita & trying to get update info from them can sometimes also be a pita, fix takes seconds & easily redone, I do often when messing with electronics in car & I have latest modules aswell, so not sure update would address this anyway.
    nelson19uk's Avatar
    Feb 2011
    Aberdeen
    152
    Thanks Nigel.
    Your wisdom is appreciated
    Vroom Vroom!
    27,126
    No worries but Paul deserves the thanks, he was spot on initially.
    nelson19uk's Avatar
    Feb 2011
    Aberdeen
    152
    Cheers Paul too. Lol
    Vroom Vroom!
    Fossie
    Rhubarb Triangle
    3,969
    Hit the thanks button as well mate !!
