Volks AutosAH Fabrications
Results 1 to 11 of 11
    May 2010
    Oslo, Norway
    142
    LED H11 Foglight bulb on 8P3
    Hello
    I installed some LED H11 bulbs in my foglights, i realy like the look, but it gives me 2 errors everytime i start the engine, is there a way to get rid of them ?
    Edit: pic added
    Sorry for my bad english.
    2010 SB TDI - Accuair E-level - Air Lift Slam front and rear - Bentley CGT 9 spokes - Votex hatch spoiler - S3 front and rear - RNS-E mk2
    v1raj's Avatar
    Apr 2009
    279
    Aesthetically the fogs looks good, but in terms of performance, noticed any difference??
    The DRL's in your headlights look 'bluer' than normal too, have you changed these?
    I thnk your errors may be down to resistors being needed. Can you provide a pic or link of the actual bulb?
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Fossie
    Rhubarb Triangle
    3,969
    By the way - your English is perfect !!
    May 2010
    Oslo, Norway
    142
    Quote Originally Posted by v1raj View Post
    They do not light up as much, but the old ones did not light up enough to use em either (in Norway we can't use xenons and fog-lights at the same time, restricted by law)
    the blue color is just from the camera, they are both pretty white with a pinch of blue.
    I bought them of eBay from some random guy (no brand) but i got a picture of the actual "bulb".
    Socket: H11
    Voltage: 12V
    68 SMD LEDs
    Light color: white
    Luminous flux: 220 - 250LM
    Color temperature: 5500K
    Lighting angle: 360
    Life: 50,000 hours
    Diameter: 18mm
    Height: 58mm
    Edit: More info
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Blimey! That's quite some LED farm you've got there!
    If you read up the other current forum threads regarding bulbs, you'll see that some cars are more sensitive than others for throwing up errors. There's resistor advice given on those threads...
    123d MSport coupe from the company
    2007 S3 in sprint blue - gone!
    May 2010
    Oslo, Norway
    142
    Quote Originally Posted by BigBird View Post
    Yeah i guess 68 in each bulb is enough
    I can only find posts about HID lights, that includes a ballast. I cant seem to find anything about LED lights..
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    where did you get the bulbs and how much where they?
    Thx
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Quote Originally Posted by grimp View Post
    Try the link below - IIRC post #26 gives the resistance of resistor to use. There have been quite a few other threads giving similar info.
    Bloody LED number plate bulbs won't work - doing my nut!
    Fossie
    Rhubarb Triangle
    3,969
    No mate !
    That was just so that you could test the voltage at the terminals without a bulb being present !
    You will need something like a 150 ohm 1 watt resistor across the bulb. Connect either way round.
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Oops! Me bad! Glad someone's here to give the right info Mike!
    Was trying to show the OP one of the many many threads that mention which resistors to use here for the newer 8Ps that are obviously more tempramental for throwing errors than my old 07 car!
    Fossie
    Rhubarb Triangle
    3,969
    No probs mate ! I used 150 ohm resistors for the sidelights of my 2006 sportback so I'm assuming they will be ok for these number plate bulbs !
    OOPS - just realised we're talking here of foglamp bulbs ! The car will be expecting a current draw per bulb of about 5 amps (55 watt bulb at 12 volts ) so, much less, and it'll throw an error I would imagine.
    Don't really think 150 ohms is going to help much but you could try it out without it doing any harm. I don't know what current draw those led's are so I can't work out the resistance required.
    Haven't had any experience with big value led's I'm afraid, sorry !
